Old 05-13-2016, 06:23 PM
GGRider01 GGRider01 is offline
Oh, of course. That is precisely the same orientation I'm using to good effect.
Old 05-13-2016, 07:22 PM
Originally Posted by RockefellerGG View Post
Yeah, confusing because there are 2 curved surfaces. Did you see the video? Should it be closing more than that?
All good and working as intended mate. That's the range of motion. I have often wondered if it would be of benefit to try and make it work over a larger scope.
As long as the flapper is down in the closed position and the drum valves open into the pv chambers all is well. Opening lifts the flapper and closes off the chambers.
Old 05-13-2016, 07:35 PM
RockefellerGG RockefellerGG is offline
Thanks!!! In the other top ends I've done, I can't recall ever looking in there to test and see the range of motion... most can't be installed backwards or upside down. Leave it to GG!
After reading some horror stories about it, I wanted to confirm.
Thanks guys!
power valve vent ? walker1008 Enduro Engine - 2 stroke 6 01-14-2010 08:36 PM
Power valve maintenance? EricP Enduro Engine - 2 stroke 2 11-20-2008 04:46 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
Power Valve rebuild Gas Stu Enduro Engine - 2 stroke 2 09-19-2007 12:38 AM
Power Valve Dilemma gasIdaho Enduro Engine - 2 stroke 5 08-18-2007 03:06 PM
