Old 10-08-2017, 11:05 AM
Mostin3 Mostin3 is offline
Default 2015 e start revisited.
Hi All,
I?ve got a 2015 ec250 and can?t for love nor money get the electric start working, despite trying all sorts. I have pulled the bendix out and it?s clean, works as it should and doesn?t appear to be anything wrong.
When I hit the start button. The bendix flings out engages with the ignition gear but then makes the most awful, hi pitched squeal I?ve heard. It does not turn the motor over.
I?m left thinking it must be one of two things, either one of the gears on the bendix spinning on the bendix shaft or the flywheel spinning on the shaft, if that?s even possible?
I have tried to replicate the former by putting one end of the bendix in a vice and trying to spin the top which I was unable to do.
I should add that the engine starts and runs perfectly off the kicker.
Old 10-08-2017, 06:45 PM
barbotte barbotte is offline
there is a thread somewhere about replacing the bendix with a old honda part that work like a charm and its like 20 $ i think
cheer
Old 10-09-2017, 03:06 AM
Thanks for the reply. unfortunately, the 2015 bendix is different to the earlier model that can be swapped with the SMU5009 scooter bendix.
Old 10-09-2017, 01:56 PM
Fojjer Fojjer is offline
Hi! Make sure you have a good battery. I unboxed my bike this winter and it made a simlilar whining noice. Sounded real bad.
New well charged battery and it sprung to life!
Low on power combined with old grease made it not turn the starter quick enough is my guess.
/MP
Skickat från min SM-G930F via Tapatalk
Old 10-10-2017, 10:36 AM
Neil E. Neil E. is offline
Fojjer is right, the bendix needs a good kick to cam out quickly. Spread the unit open and wash it out with brake cleaner or solvent. Then oil it completely with a light motor oil. Jump your bike battery with a car battery and see how it performs.
Old 01-24-2018, 07:49 AM
giov81 giov81 is offline
Default good morning
hello, I have this problem too, have you solved it?
the grease in the teeth of the bendix should be put or does it slip?
Old 01-24-2018, 06:33 PM
Nocams Nocams is offline
ive had to grind back, weld and then machine the thick end of the bendix (the end that is located in the outer cover) as it was spinning the inner shaft of the bendix inside the outer housing that has the cast in fine gear.
This can be checked by gripping the outer (fine) bendix gear in a vice (with plastic jaw protectors) then seeing if the gear that contacts with the flywheel gear can be turned (a well worn one will turn by hand,one with a fresh problem may need vise grips to turn to find the problem.)
Hope this helps!
Old 01-25-2018, 10:58 AM
Light grease is OK on the teeth; the inside workings are better with oil. Nocams is describing testing the "sprag" elements. Worns sprags will slip, new ones will cam into engagement and drive properly. The sprags are inside the cover and are held by the "gathering spring".
2015 Gasgas ec 300 e-start seitz331 Used Bikes 3 09-17-2017 06:25 AM
2015 XC300 e start tzsuzuki Used Bikes 3 07-06-2017 09:02 PM
2015 E-start burned Dj_Zorba Enduro Engine - 2 stroke 24 03-29-2016 05:50 PM
2015 GasGas EC300 E-start wilmington_powersports Used Bikes 2 12-03-2015 10:51 AM
EC300 Idle Revisited. Ud_luz Enduro Intake/Carburetion - 2 stroke 35 01-07-2011 07:39 PM
