Old 04-11-2016, 01:46 AM
Caravan Monster's Avatar
Caravan Monster Caravan Monster is offline
Thanks Anders ! Very much appreciated ! I would have taken a very long time to find that information. The depth of knowledge on GasGas Riders is impressive as ever.
Hopefully rewiring will be the solution to this problem.
'00 Montesa Cota 315R
'13 Husaberg TE 300
Old 04-18-2016, 02:34 PM
For posterity, the JAE Electronics part numbers for the 2k3 cdi multipin connector on the '06 EC:
CONN SOCKET HOUSING MX23A18SF1
CONN FRONT CAP 18POS SOCKET HSNG MX23A18XF1
CONN DUMMYPIN FOR MX23A SERIES M120-55780
CONN SOCKET 16-22AWG CRIMP MX23A M23S05K351
I have replaced the dubious wires from the cdi to the coil / earth / kill switch and also replaced the ht lead and plug cap. The spark is now noticeably stronger. However, there is still a problem starting from cold. I have found a routine which overcomes this:
fuel on > fill bowl (lectron visual check) > fuel off > choke on > kick until starts > fuel on > choke off
If I don't switch the fuel off, it will not start. If I follow the routine, it starts from cold easily and starts and runs great. I suspect the fuel level creeps up in the lectron bowl if I kick it over many times without start, whether this is enough to flood the engine, not so sure. I did find one report of swarf from the slide / tickover screw finding its way to the float valve. I'm hesitant to attribute blame to the lectron because the bike is old and there could be other problems to be found.
Hope that's the end of this problem, having missed several rides because of it
'13 Husaberg TE 300
Old 04-25-2016, 01:58 PM
Rode for a few hours at the weekend with no problems, so hopefully the issue is resolved.
'13 Husaberg TE 300
Old 04-26-2016, 03:17 PM
Anders's Avatar
Anders Anders is offline
That is good news. Lets hope it stays that way
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Thread Tools
Display Modes
A lot of fault spark plugs... dimtsam Enduro Intake/Carburetion - 2 stroke 6 11-14-2014 09:51 AM
EC200: Ignition test 2K2 vs 2K3 firffighter Enduro Engine - 2 stroke 2 08-26-2014 11:41 PM
Fuel tap fault Warwick Simpson Enduro Intake/Carburetion - 2 stroke 0 11-09-2008 12:15 AM
EC200 ignition ? mudskipper Enduro Electrical & Wiring 4 09-05-2006 08:38 PM
