Old 10-30-2018, 08:47 PM
gasgasman's Avatar
The voltage regulator will keep the charging voltage below 15V.
Voltage always return to its source. The charging voltage just circulates through the battery- "recharging" it.
Old 10-31-2018, 05:24 AM
Cox76y Cox76y is offline
aha, thanks gasgas man. That explains it.
Old 11-04-2018, 02:51 PM
Wuzofoz Wuzofoz is offline
I fitted a volt digital volt gauge to the bike and headed out yesterday with 15v in the battery.
I only used the kick starter all day and while running the fan the volts dropped. At 14v fan off to check for charging and nothing. I related this at 13.5 and 13v. At no point all the way to 12v did the dash show anything except full charge.
At 12v there was some recharging but very low like an hour to bring up to 13v.
Will call the dealer now
Old 11-04-2018, 09:19 PM
Dealer says it?s a 12v system and anything above 14v is overcharged and my expectation of the bike charging to 15v as sstated on the battery is unrealistic.
Old 11-04-2018, 11:41 PM
Gasser Nate's Avatar
The charge rate for a 12v system is anywhere between 13.5-15.5 volts. If you are at 14volts it is perfectly fine!
Old 11-05-2018, 02:53 AM
After a heap of research today I?ve come to the same conclusion. I think I got caught up in the bike starts fine at 15v and not at under 14v that the batts not being charged above 14v. Research shows battery chemistry is LiFe and they would be 14.4v fully charged (assuming 4 cells). I have been charging to 15v with a LIPO charger set to 15v termination so very good chance I damaged the battery causing the problem.
Old 11-11-2018, 01:42 AM
Today?s ride has confirmed it was a bad battery. The new battery was charged to 14.4 a couple days ago and by this morning was showing 13.6v. I used the kick for cold start and E start the rest of day. Battery had close to 13.5v every time I checked and started fine all day without issue.
Charging question EC250 2013 e stsrt periclesgsilva Enduro Electrical & Wiring 2 08-02-2017 09:40 PM
Charging kiwigasgas Enduro Electrical & Wiring 25 10-06-2016 03:59 AM
not charging battery OLD.IT Enduro Electrical & Wiring 2 06-21-2015 03:01 AM
Charging phone on 2011 EC300 Quigs Enduro Electrical & Wiring 9 03-07-2015 12:55 AM
Battery Not Charging GLantern Enduro Electrical & Wiring 6 08-25-2013 03:45 PM
