Old 12-20-2015, 10:31 AM
tzsuzuki tzsuzuki is offline
Default Strange thing going on
I have a 2015 GG 300. Love the bike! Every once in a while for reasons I have yet to discover the exhaust note will suddenly become very loud and crisp along with a momentary reduction in power. It clears up in a second or two. Very erratic might not occurs for several rides then do it several times on a ride.
I thought the O rings at the exhaust spigot might be failing, replaced them.
I do have a Lectron carb and HOH silencer otherwise stock and about 60 hours.
Any thoughts?
John Farrell
AMRA 8M
2015 GasGas XC300 race
Old 12-20-2015, 11:44 AM
GGRider01 GGRider01 is offline
Could be a momentary lean condition.
Old 12-20-2015, 11:57 AM
slocalspode's Avatar
Power valve sticking open due to carbon build up.
Mine will do it too from time to time.
JJ
Old 12-20-2015, 12:03 PM
pigpen966 pigpen966 is offline
+1 on the power valve, my 13 did it when it was new.
Dick Carnes
"If ya run, you'll only die tired"
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
2006 DE 300 (buddy has it)
Old 12-20-2015, 01:22 PM
CombatYoga's Avatar
CombatYoga CombatYoga is offline
Another vote for the powervalve sticking.
It was happening on my 2014 300 - the exhaust note would change just as you said.
I found that it was happening over log crossings or other abrupt landings.
I cleaned it up as best I could and it improved, but I am in the middle of a top end job and plan on taking it completely apart to get it cleaned. If I can find someone to bead blast some of the parts I'm going to do that.
Slade
'14 GG XC300R - County Cycle Woods Weapon #63
Old 12-20-2015, 02:22 PM
TheLetterJ's Avatar
TheLetterJ TheLetterJ is offline
Easy Off (or other) aerosol oven cleaner works great for cleaning carbon of of STEEL parts, just try not to use it on anything aluminum. I just cleaned the PV flapper and both drums with it. Spray it on, let it sit overnight, light brushing with a stainless brush, rinse with hot soapy water, and they look brand new.
I thought about glass beading the drums, but I figured the slightly rough finish would allow carbon to accumulate faster than the polished finish of OEM. Good idea for the flapper anyway.
Old 12-20-2015, 02:43 PM
I use the wire wheel to clean it off after you disassemble it.
Old 12-20-2015, 03:57 PM
This is what I do too. Quick and easy and not all that messy.
Old 12-21-2015, 08:53 AM
Default Strange noise
Thanks for the replies.
I thought that might be a possibility (power valve). I have around 70 hours I will have to look into that.
I was worried that it might be a air leak
John Farrell
AMRA 8M
Don't do the right thing. noobi Injury & Recovery 20 05-13-2012 06:09 PM
200 Jetting, help me sort this thing noobi Enduro Intake/Carburetion - 2 stroke 20 03-27-2012 03:39 PM
My powervalve cam t thing doesn't look right rgranger Enduro Engine - 2 stroke 12 07-11-2011 12:41 PM
and then this thing broke.... dank Enduro Intake/Carburetion - 2 stroke 2 03-21-2010 05:18 PM
A funny little thing... FFRDave Enduro Suspension 3 09-23-2006 05:15 PM
