Old 08-14-2019, 02:09 PM
Jinx_pt Jinx_pt is offline
Default Gearbox oil 2stroke
Hi guys!!
Has anyone use this and what are your thoughts:
-MOTUL TRANSOIL EXPERT 10W40
-CASTROL MTX 10W/40
-BELRAY GEAR SAVER 80W
-MOTOREX GEAR OIL RACING 10W/40 = Using now
-GRO 10W/40 = Used before
I dont have a lot of choice with in the stores, but want to try something else.
My 2013 gasgas 300r has the typical rattle in the gearbox (sound on neutral, but goes away if if press clucth) and occasionally slips under heavy load. So im trying to find the best oil with the choices i have...
Thanks in advance!!
Old 08-14-2019, 05:09 PM
You almost have to try different oils and see what works best for you.
I use Castrol full synthetic, either 0w/20 or 5w20.
Both work well for me.
Old 08-14-2019, 06:48 PM
Every motorcycle with straight cut gears has that rattle to some extent. Nothing to be worried about. Run a good quality oil that doesn?t make the clutch squeak and you?ll be sweet! Castrol, Gro, Belray are all good.
Old 08-14-2019, 07:58 PM
Motul Expert works great for me at least for lack of drag or slip.
Old 08-15-2019, 01:47 PM
I like to use Pro Honda HP Transmission Oil 80w/85w.
Old 06-21-2020, 01:25 PM
RockJunkee's Avatar
RockJunkee RockJunkee is offline
Same here!
Old 08-15-2019, 01:49 PM
I have heard that some people like to use lower viscosity gear oil to reduce clutch squawking. I personally have not any issues with this on any of my Gassers, but might help if you have a noisy clutch when abused.
Old 08-15-2019, 03:17 PM
I have only ever used belray gear saver (changed every 10 hours) and i am well past 300 hours
Old 08-16-2019, 06:53 AM
RBrider's Avatar
RBrider RBrider is offline
Thumbs up
It'd be hard to do better than the BelRay Gear Saver, imo.
RB
Old 08-16-2019, 08:22 AM
RudolfHucker's Avatar
+1 for the Motul. I haven't tried the others.
2stroke oil- full,semi or neither damo18 Enduro Engine - 2 stroke 30 03-16-2018 09:33 AM
Gearbox oil 10 40? Capz85 Enduro Engine - 2 stroke 4 05-24-2015 08:59 AM
Gearbox oil eviljim Enduro Engine - 2 stroke 37 06-07-2014 01:34 AM
250 2stroke 28gasser250 Riding Techniques & Training 10 03-12-2013 08:15 AM
Air filter access on electric start 2stroke's Woodsknight Enduro Chassis & Body 23 12-17-2011 04:47 PM
