Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Enduro Technical Forums > Enduro Other...
Old 05-08-2016, 07:23 PM
Munch Munch is offline
How much did you pick the bike up for?
I don't think you will need the full kick start assembly, you should be able to just purchase the part causing you problems
Old 05-08-2016, 07:45 PM
Tiddlesrx7 Tiddlesrx7 is offline
More than I wanted! Someone else started bidding in the last 10 minutes :-(
Old 05-10-2016, 03:21 PM
So it turns out the kick start fault isn't a slipping issue. When you twist the kick start 90 degrees so that you can start the bike, it actually moves more like 120 degrees. So when you kick the bike over you slip off the starter. I presume its just a problem with the ball and spring that locate it at 90 degrees. I'll have a look tomorrow when I get a minute.
Old 05-10-2016, 03:27 PM
nknudsen's Avatar
nknudsen nknudsen is offline
A Yamaha kicker is a popular upgrade for the GG.
Noah
2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title
16' Ski-Doo XS Renegade X 1200 4T
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been)
15' TW200
Old 05-10-2016, 03:53 PM
Any particular year/model of Yam? Although I hope I can fix the original one.
Old 05-11-2016, 03:49 AM
I had a quick look at it this morning before work. It seems like the aluminium machined face at the bottom of the kick start is worn, this is allowing it to turn more than 90 degrees. Hopefully it will be an easy fix with a blob of weld and a file.
difference between ec250 and ec250 race? Dirt Addict General Discussions & Announcements 2 10-24-2009 02:56 PM
