Old 10-11-2018, 02:04 AM
Originally Posted by Gasser Nate View Post
Yep you are all over it. The right hand side assembly is different to earlier ones. Be reall careful taking it of, mine was stuck down tight on one side. Depends too on where you run the adjustment screw as well. Mine is out pretty far, about three turns.
RHS engine cover? Or PV cover?
I know the engine cover changed due to the PV tension adjuster. Might have to have a closer look at the whole shebang.
Head came back from TSP today. Have to measure the squish and see where it ended up. Strange that they didn't put any of the details on the invoice.
Old 10-11-2018, 06:01 PM
Gasser Nate's Avatar
Yeah that pissed me off too. I would have really liked to have got some details. I even emailed and asked for them and got nothing back. The right hand side power valve was the one stuck on good. But if yours has not been running yet it might come off easy. The right hand side cover uses those beautiful reusable foam lined foil gaskets.
Old 10-11-2018, 08:30 PM
shawbagga's Avatar
shawbagga shawbagga is offline
What is this PV tension talk you speak of? Something I need to check or what?
'18 Gasgas XC250
Old 10-11-2018, 09:37 PM
Bugger me! I better order some of these 'new' PV gaskets then. Murphy says it's torn before I even try to remove it. I thought being new it might be OK but I already tore the flywheel gasket removing that, so I'm not optimistic.
I have 2 spare right engine case gaskets here so no concern.
I think I'll wait until I change the first oil or something.
Old 10-11-2018, 09:38 PM
I shot Dave a message on FB. I don't think I'll get an answer either. Appears they are quite loaded with work. Churnin em out!
Old 10-11-2018, 11:19 PM
Slideshow Slideshow is offline
Emailed them last week to get an idea of what it will cost me, no response yet.
Hope they get on top of it soon!
Old 10-12-2018, 01:05 AM
Same as on the early ones, some needed a bit more tension on them, some didn?t. Usual gassy specialty! Easy to check but a tad more involved to adjust. Right hand side power valve cover off to see if it has more than a bees pecker of play.
Old 10-12-2018, 11:30 PM
Took some time to measure up the new head work.
1.00mm at the edge, opening up to 1.50mm across the band; 2.4 degrees.
Haven't measured the volume yet! Guess I better do that.
Old 10-13-2018, 12:32 AM
Bugger me..
Combustion chamber cc's at 21.5cc
250cc piston dome has always been around 6.6cc
Volume of 1mm squish clearance is 3.46cc
Total trapped Volume 21.5 - 6.6 + 3.46 = 18.36
Compression Ratio (18.36 + 249)/18.36 = 14.56
Bit high I think..
If.. it was cut to 1.25mm as requested the ratio would down to 13.93:1 ...which is where my old 2010 was set. Last bike was 13.2:1
So so so.. Where to from here.
Old 10-13-2018, 01:52 AM
Bugger me..
Bit high I think..
I?d be sending it back. If you asked for 1.25mm it should be close at least.
TSP head mod - 2018 EC250 Gibnut Enduro Product Reviews 27 04-27-2019 09:25 PM
2018 ec250 jetting help!! Leelee Enduro Intake/Carburetion - 2 stroke 4 08-13-2018 07:59 AM
2018 GG EC250 riders help please. Gibnut Enduro Engine - 2 stroke 6 08-03-2018 06:10 AM
Gas Gas 2018 EC250 Six Days - 4th ride Gibnut Pictures & Videos 3 02-28-2018 12:07 PM
Gas Gas 2018 EC250 Six Days Gibnut Enduro Product Reviews 14 01-23-2018 12:00 AM
