Old 04-17-2010, 08:46 AM
SideshowBob SideshowBob is offline
Default Help! Flywheel weight doesn't fit with 2k3 on 2003 EC250?
Is this normal? I think it's a 10oz or 12oz flywheel weight... I bought it from Go Fasters, it fit my MC250 with a 2k2 fine.
There isn't enough room behind the cover.... hmmmmm
2003 EC250 w/ Ohlins pkg
Sometimes you eat the bear, sometimes the bear eats you.
Old 04-17-2010, 09:18 AM
flybars flybars is offline
At 60 and coming off of 4 strokes, I was hoping to add more weight to '03 ec250 too. Can U shim the cover out? Is that the problem?
'14 Beta 300rr
'05 GG DE300
'03 GG EC250
'01 XR440
'09 FZ1
Old 04-17-2010, 09:25 AM
Just measured it, it's about 11 oz's. Checked the MC, the 2k2 is much closer in (I knew this). The plastic cases are exactly identical on the two bikes.
Old 04-17-2010, 09:26 AM
It's a solid half inch or so that would need to be shimmed. I am wondering if this is specific the flywheel weight I have, because it seems others have them on 2k3's?
Edit- Mine has a nut on the outside of it, if the nut was flush it would be close to fitting...
Old 04-17-2010, 11:14 AM
HuskyDude's Avatar
HuskyDude HuskyDude is offline
You should give Mark Berg from GoFasters a call and explain to him your problem. 320-839-7143
I'm considering a fly wheel weight too. I would like to know the out come of this.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 04-17-2010, 02:32 PM
I will on Monday, too late now though....
Old 04-17-2010, 09:56 PM
roostafish's Avatar
roostafish roostafish is offline
It's not uncommon to need to shim out a cover for a flywheel weight. A half an inch seems excessive, but it wouldn't surprise me too much. A freind of mine once built a 22oz flywheel weight for his bike. He purchased a brand new flywheel cover and cut his old one off the amount he needed for a spacer, then used two gaskets, one on each side of the "spacer" and used longer bolts. Looked sano, and didn't leak.
Mike Sheetz
OMRA #21AA
What will I be riding next? Christini GG 300?
'15 KTM 300 XC-W
'08 EC 250 (Gone to new happy owner)
Gran Prix Cycle
LTR Suspension
RB-Designs
Old 04-19-2010, 05:54 AM
hmm I could hack the old one up with a dremel....
Old 04-19-2010, 06:59 AM
GMP's Avatar
GMP GMP is online now
I don't beleive those weights were ever intended to fit on a 2K-3 flywheel. The 2k-3 has close to double the inertia of the 2K-2 with a 12oz added. Consider a G2 throttle with a #400 cam if traction control is an issue.
Old 04-28-2010, 04:18 PM
Brian's Avatar
Brian Brian is offline
I have a question sort of along these lines...I have a 2k-2 in my bike and I bough a 2k-3 to install from widebear. Just getting my parts list together to put a headlight and swap to the 2k-3...anyways.
I'm trying to determine if I got the flywheel as well. If you look at the following picture. http://www.gofasters.com/images/EC200_ignition-2006.jpg item #5 I have that complete assembly...is that outer piece that is closest to the case the flywheel?
2006 Gas Gas EC250
2011 Husaberg FE390
flywheel weight ? GAKLX Enduro Engine - 2 stroke 17 11-10-2008 09:01 AM
DE and EC flywheel weight GregM Enduro Engine - 2 stroke 11 05-20-2008 04:46 AM
