Old 06-04-2010, 01:49 AM
Kurdt Kurdt is offline
Default Scorpion Racing Radiator Frames and Skid Plates
Anyone using Scorpion Racing's rad frames or skid plates? How is the fit and install? They look like real quality pieces.
2010 GasGas EC 300 Nambotin Replica #141
2006 Honda XR650R Supermoto
Old 06-04-2010, 05:46 AM
SideshowBob SideshowBob is offline
Yep, I have their GG Skid Plate. Install was snug but good, skid looks and has been so far completely indestructible.
2003 EC250 w/ Ohlins pkg
Sometimes you eat the bear, sometimes the bear eats you.
Old 06-04-2010, 06:11 AM
HuskyDude's Avatar
HuskyDude HuskyDude is offline
Kurdt, The Scorpion skid plate is the way to go, although a little work needs to be done to make it fit the new frame. I'll check tonite for the exact length of bolts and spacers needed the one sent will not work for the 2010 frames. If you contact Scorpion themselves. They will send you the right ones. I gave them the new measurements needed. I also had to notch the front a bit for the exhaust bracket.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 06-04-2010, 09:14 AM
I've got a scorpian on my 08 cr 125 ... they were one of the few companies that made on for it. build quality is excellent. if they made one to fit a gas gas I had and I needed a skid plate I'd get another one
Old 06-06-2010, 08:16 PM
motorhead's Avatar
motorhead motorhead is offline
can anyone give a comparison between crd and scorpion? My crd rad. guards have seen better days and I'm thinking of trying the scorpion guards.The crd's fit well and did the job but after alum. gets bent repeatedly,well you know
Old 06-07-2010, 01:33 PM
NerdFrog NerdFrog is offline
Got the skid plate and the rad guards/braces for my '07 EC300 from Scorpion. The bike tumbles over/under/through a lot at McNutt on my weekly rides and the guards do their job admirably. Fit & finish perfect - easy and solid install.
I only had to pull the right wing back away from the water pump once after a hard get-off into some river boulders. The guard never contacted the pump cover, just got closer. I pulled it back so it could do the deed again without bending in even further.
Prior to the scorpion guards, I was running a Hyde combo. The Hyde lasted one season before it fell apart at the pipe and lower mounting brackets. The scorpion is on it's second year and still going strong.
Ride to work: Pedal bike or 1986 Suzuki GS400S
Ride for fun: 2007 GasGas EC300
www.FVDRA.com
http://www.bluemountainmotorcycleclub.com
www.TeamCoastalCycling.com
Old 06-07-2010, 04:39 PM
HuskyDude's Avatar
Kurdt, If you end up getting the Scorpion Skid plate.
Call Steve Vander Helm. Owner of Scorpion Racing Inc. Tel: 604-490-2128
He'll send you 4- 45mm bolts and 4- 30mm pvc spacer. with your new plate.
He might even have made up the package with the new stuff already in it.
Not sure where he is on his new Rad Guard/Brace. Last I heard he was working on a combo.
Can't wait I'm sure it will be the best one out there when finished.
Good Luck
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 08-15-2010, 06:36 PM
What do the pvc spacers do? are they simply there to protect the bolt threads?
Old 08-16-2010, 05:30 PM
HuskyDude's Avatar
The PVC spacers are there so you don't inadvertently warp the plate when snugging the bolts up.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Anyone installed Scorpion Racing Radiator cages on a 2010 model? Kurdt General Discussions & Announcements 6 08-11-2010 06:26 AM
skid plate & rad frames motodave63 Enduro Product Announcements 2 05-02-2009 10:37 AM
Hyde Skid Plates fury1 Enduro Product Reviews 48 11-26-2008 07:45 AM
Skid plates and Rad Gaurds 2 strokes 4 life General Discussions & Announcements 3 08-18-2008 07:47 PM
