Old 03-06-2011, 03:53 PM
Stoby's Avatar
Stoby Stoby is offline
Bronze Level Site Supporter
Default 250 -300 conversion
Can anybody tell me if you can convert the 250 to 300 by changing jugs ?
i thought that was what i had read ,but I saw asomewhere that the stroke is different ???If thats so, than it wouldn't work properly,right?piston height and cylinder ports would be off.Does anybody know for a fact by having done or not been able to do it?
Thanks
Stoby
Old 03-06-2011, 03:59 PM
einsteingarage einsteingarage is offline
You can do it. Take a 250 bottom and put on a 300 top and run like the wind. Never done it but had planned to. As I understand it, jug, head, and piston.
Old 03-06-2011, 04:29 PM
Stoby's Avatar
Default Heard
Thats the thing i've heard it can be done but who has done it .if the stroke is different the port timing would be off and more.
Old 03-06-2011, 04:37 PM
noobi's Avatar
noobi noobi is offline
Stroke is not different. Both 250 and 300 run a 72mm stroke, the 300 has a 72mm piston so is a square bore x stroke, the 250 has a 60 something mm stroke.
100% works
Old 03-06-2011, 04:46 PM
PEB PEB is offline
Go for it, totally bolt on affair.
Old 03-06-2011, 07:11 PM
GMP's Avatar
GMP GMP is offline
The PV parts swap right over to the 300 cyl too. Don't forget you will have to rejet.
Old 03-07-2011, 01:01 AM
Elvis74 Elvis74 is offline
sorry that this is in german, but maybe it helps:
http://www.offroadracing-pilz.de/sho...uf-EC-300.html
4 strokes are only good for power generators
250 to 300 Conversion Kurdt Enduro Engine - 2 stroke 10 03-30-2010 09:41 AM
ec 125 conversion? eddy field1 Enduro Chassis & Body 1 09-03-2009 09:00 PM
07 200 to 05 conversion brains Enduro Engine - 2 stroke 5 07-12-2009 12:54 AM
MY FSE 450 to SM conversion cal_tony Pictures & Videos 11 02-05-2009 10:11 AM
