Old 06-17-2011, 05:16 PM
dickieshep dickieshep is offline
Default final drive sprocket seal
I have found the seal behind my drive sprocket is leaking, is it easy to change or am I looking at a big strip down.
Old 06-17-2011, 09:43 PM
Easy, comes out from the outside with a seal puller or hook once the sleeve is removed from the shaft. An o-ring also seals the rear of the sleeve. If you see oil coming from between the shaft and sleeve this is the problem, not the seal. Its a good idea to replace all three.
Old 06-18-2011, 03:32 PM
Cheers for that GMP.
Final drive seal? nick790 Enduro Engine - 2 stroke 2 10-14-2009 03:37 PM
Steel Drive Plates nr1strange Enduro Engine - 2 stroke 1 08-11-2008 09:41 AM
Final drive chain anathema Enduro Engine 4 stroke (including EFI & Exhaust) 3 04-14-2008 08:44 PM
Counter shaft Sprocket Seal Rick Enduro Engine - 2 stroke 4 12-03-2007 09:00 AM
