Old 04-04-2013, 03:14 AM
jcborden jcborden is offline
Default 2005 to 2011 transformation questions
Hi all, been lurking for a while and have a 2005 EC 300 which I purchased the transformation kit for to take it to 2011.
Have read the other transformation threads which has provided some very useful information, particularly on the air box side of things which having read the other threads was actually pretty straight forwards.
So, here is a picture showing where I am up to:
And on to my questions, some of which I am sure are silly, but hey might as well ask:
1. My CDI sat under the tank in a recess in the old airbox - I assume you just move it into the new airbox, but where does it sit and how did you secure it?
2. The mud flap that protects the shock absorber attached to the old airbox by two 6mm bolts (with recessed nuts on the airbox), looking at the new airbox there are just two holes drilled in the plastic - do you just use self tapping screws to secure it?
3. My side stand hits the undertray which can't be normal - any suggestions on how to resolve?
4. The airbox just presses together and is held in place by the subframe - do you seal the joints with anything or just rely on the press fit to keep the worst of the mud/water out?
5. The rear LED brake light has a short lead and connector fitted - is it a special/gas gas connector or a standard one that a car shop would sell? Or do you just chop it off and solder to the existing wiring?
I am sure there will be more, but having got the airbox/boot sorted I feel like I am making good progress.
Cheers.
Old 04-04-2013, 12:42 PM
nknudsen's Avatar
nknudsen nknudsen is offline
We're at different stages of our kit installs but this is what I've found so far.
Make sure the subframe/tail is centered over the rear wheel. The hole location was off on mine at the right top strut that mounts by the tank. If forced into position it made the subframe crooked
Obstacles so far with my 2000 EC250 (not done yet)
*Hole location off on one subframe strut (top right)
*2000 or 2011 FMF TC2 silencer won't fit correct
*Shrouds needed sanding/fitting on the inside to mount to the tank decent
*seat fits very very snug to back bone of the fuel tank
Could your side stand just be bent/tweaked out a bit to clear?
Good luck with the project!
Noah
Noah
2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title
16' Ski-Doo XS Renegade X 1200 4T
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been)
15' TW200
Old 04-04-2013, 03:54 PM
Hi Noah,
I've got the FMF TurbineCore 2 for a 2007 and the mounts will line up but I can't get it to slip over the end of the header, strange as the FMF I've taken off fitted over just fine. Not sure what to do with this...
There seems to be a lack of fixing points to attach the under tray to the subframe. Need to take another look to see if I've missed anything.
Old 04-04-2013, 04:26 PM
djroggen's Avatar
djroggen djroggen is offline
The diameter of the pipe from older bikes is larger than the diameter of the newer I believe 07 and newer run. Forgot about that fact.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Old 04-04-2013, 04:34 PM
Neil E. Neil E. is offline
On the 2011, there are two screws that go into the frame from the outside. They attach the plastic CDI holder to the frame.
2011 EC250E
Old 04-04-2013, 06:26 PM
View from the inside of the "airbox". The bottom of that CDI holder is screwed down to the airbox. A rubber strap anchors the CDI unit to the holder.
2011 EC250E
Old 04-04-2013, 08:42 PM
nknudsen's Avatar
Thanks for sharing the pictures!
Noah
15' TW200
Old 04-05-2013, 02:24 AM
Tigger52 Tigger52 is offline
When I did mine the shock mudflap bolts were of the self tapping variety so I just re used them and they gripped just fine.
My side stand had a bolt fitted by the previous owner that limits the movement just enough - I think this was because he fitted 2004 plastics on the 2002 bike and the stand was touching the side panel.
I zip tied my CDI unit to the subframe rail, but I'm going to mount it properly now I've seen those pics - thanks
Old 04-05-2013, 08:13 AM
The pictures are very helpful, alas I don't have the plastic bracket for the CDI so will make something up.
I spend quite a lot of time this morning trying to fit the rear plastics only to find that nothing lined up, after a bit of head scratching I realised the airbox was just too far forwards and with a bit of tugging and swearing it is now nearly lined up but should all fit OK.
I will have to see if I can restrict the stand movement or straighten it a bit to stop the hitting.
My biggest issue now is the silencer. I have put the FMF for my 2005 next to the FMF for the 2007 and the outer pipe diameter looks to be the same but there must be a slight difference on the internal diameter. I will try a bit of brute force along with some gentle grinding to see if I can persuade it.
Old 04-05-2013, 09:48 AM
There was a small hole in the top side of my sidestand receiver. I found a small rubber bumper in my junk drawer and the mounting stub fit through the hole. The head of the bumper was just right to to keep the stand from clunking when it swings up (I changed it to no auto retract).
2011 EC250E
transformation kit help needed nknudsen Enduro Chassis & Body 5 03-29-2013 11:16 AM
2005 to 2011 transformation whodat Enduro Chassis & Body 23 03-22-2013 10:30 PM
Gasgas transformation kit Crombie General Discussions & Announcements 2 03-01-2013 04:27 PM
Questions re 2011 GG 300 n_green Enduro Engine - 2 stroke 5 10-05-2012 07:36 PM
2011 Ec250 wiring questions toolmaker General Discussions & Announcements 0 01-04-2011 07:38 AM
