Old 03-24-2019, 06:56 PM
ReaptheHeat ReaptheHeat is offline
2018 XC 250
Altitude: 6000-9000 ft
Temp: 55 F
Pilot: 38
AS: 1.5
Needle: Stock @ #2
Main: 168
Little bit of spooge after a 1.5 hour race today, mostly on the needle. When I am WFO, feels like it never tops out. Is this more of a lean or rich symptom?
Otherwise, I might throw in the JD red or Blue to see how it feels.
Old 04-11-2019, 06:54 PM
Originally Posted by ReaptheHeat View Post
2018 XC 250
Temp: 55 F
Pilot: 38
AS: 1.5
Needle: Stock @ #2
Main: 168
Rode at 5000 ft 70 F.
JD Blue #2, 38 PJ, 170 Main. Excellent feel, could probably run a 168 main. This is the best I have gotten either my 2012 or 2018 jetted. Too bad I rarely ride this low in elevation. Zero spooge.
The kit rec. 42 PJ, Red #3, and 168 Main for 5000 to 8000 ft. I found the PJ to load up too easily for lugging, then feels lean down low with the smaller 1/4 needle taper, then opens up to a nice powerband.
Is there a needle one step leaner than the JD blue with the same taper profile?
Old 06-26-2019, 05:38 PM
Jinx_pt Jinx_pt is offline
Default Gasgas 300 R 2013
Hello!
So, after reading a lot in the forum, testing with the bike and see how it feels, jetting is like this.
AS2 carburetor
Needle & notch =NECW #2
Main jet = 172
Pilot jet = 42
Air screw setting = 2 1/4
Throttle valve:7
Fuel: 95 oct (can use 98 if better for jetting)
Oil:MOTOREX CROSS POWER 2T at 1.5%
Elevation: Sea level to 500m
Temp C?: Summer 20 to 35 / Winter 0 to 15
Riding type: Hard enduro single track and rocky creeks.
I had problems with fouling plugs, just the usual with gasgas factory settings so i had to deal with it. Adjust float level, clean the air filter, carb, pipe and muffler. After all that, changed stock needle
Bike goes a lot better, smooth but with power, starts easy even after a crash (before had to try several times) and fuel consumption has improved a lot!!
I just started with jetting, so if the jetting gurus see that any setting is wrong or could be a bit better please tell me!!
Thanks
Edit: Been using 98 oct from the local pump and plug have a better color!!
Old 06-26-2019, 05:52 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Thanks
Hi, I don't call myself an expert but the only thing I could suggest is trying a smaller pilot as your Air Screw is 2 1/4 turns out. Of course, if it's running nicely then why bother?
My jetting is pretty similar to yours, although mine is a 2004 EC300 with the AS1 carburetor.
All the best, Dave.
P.S. I love Portugal, where are you in Portugal?
Old 06-26-2019, 06:10 PM
All the best, Dave.
Yes, i was thinking of going with a 40PJ, but if i can manage with the 42PJ during summer, (since i dont ride a lot in the summer, too damm hot ) later in winter that air screw will be close a little.
I live close to Porto and even closer to Lagares, home of one of the best hard enduro events, the Extreme XL Lagares.
Thanks for your replay Dave.
Old 06-26-2019, 06:12 PM
Davehuge's Avatar
Sounds like a good idea.
Have fun!
All the best, Dave.
Old 08-05-2019, 12:57 AM
rodent's Avatar
rodent rodent is offline
Bike year & model ='19
Temperature (degF) =53
Elevation (feet) =900
Main jet =175
Pilot jet =42
Needle & notch =NECW/3rd
Air screw setting =1 1/2
Throttle valve/slide =Standard(I didn't look )
When I got the bike new it had an N1ef needle in it and the sucker was very fat on the last 1/4 of throttle when rolled on from low speed in top gear.
I've since changed to NECW and left the jetting the same, went out today and down low the bike feels substantially "crisper/responsive"
Not near as bad as before, when you roll it on in top gear at a slow speed you get to that last 1/8th throttle and it lays over(fat).
It feels bad enough that I don't feel that dropping the needle one groove will have enough impact, I am steering toward going with a 172.5 main and leaving the needle where it is.
Thoughts?
Old 08-05-2019, 03:05 PM
Main jet =175
Pilot jet =42
Thoughts?
Hello Rodent!
Yes the stock needle is baaaaad!!
This is my opinion, base on what i have learn in this forum and testing on my bike.
Always keep an eye on the spark plug color to see whats going on with the engine!!
What notch, 3???
Going with the 172 MJ is a good idea. Try that and see how it feels...
If your not happy after that, you can lower the needle one notch.
My setting is similar, but with a 2013 gasgas.
Old 08-06-2019, 01:33 AM
rodent's Avatar
Hello Rodent!
What notch, 3???
Yeah it's in the 3rd groove, I'll leave it where it is and throw the 172 jet in and see how I get on........hopefully get out this weekend for a test run
I don't mind if it's a bit fat, but I'd rather not be going through plugs flatout
Thanks for the reply
Old 08-06-2019, 05:16 AM
Davehuge's Avatar
Hi Rodent... Just wanted to check... you're using fully synthetic oil at 50:1 / 2% ?
The jetting database needs your help! MattR General Discussions & Announcements 4 10-18-2017 05:34 PM
JD Jetting settings for linear power delivery? SpeedyManiac Enduro Intake/Carburetion - 2 stroke 5 04-06-2010 06:17 PM
Modification/Aftermarket Database SpeedyManiac Enduro Product Reviews 4 02-04-2009 07:09 AM
Jetting Database Announcement MattR General Discussions & Announcements 0 12-18-2008 08:58 PM
Jetting Database Summary MattR Enduro Intake/Carburetion - 2 stroke 0 12-18-2008 08:36 PM
