Old 09-10-2018, 04:57 PM
Alberto17 Alberto17 is offline
Thanks! appreciate all the information provided here!
Old 09-10-2018, 05:24 PM
john r b's Avatar
john r b john r b is offline
Originally Posted by Alberto17 View Post
What is the difference between those 2 in terms of bike performance?
I am afraid I bought a cheap one(china) and that is why it does not work good
You receive what you paid for..
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 09-12-2018, 12:22 AM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Originally Posted by Davehuge View Post
There's no difference in performance between the AS1 and AS2, both will work great on your bike...
BUT it's essential to get your carb setup correctly, or it won't run correctly or may not even start at all!
Start with the basics, clean air filter, good spark plug correctly gapped, new fuel with good quality 2 stroke oil (usually 2% for full synthetic but check). Check rubber tube between carb and reed block, on older bikes the rubber can perish and split causing an air leak, it's not expensive to replace.
Then check carb, remove main jet and pilot jet, inspect/clean. The hole in the pilot jet is very small and can easily be blocked.
Remove float and float valve, clean/inspect. Rubber tip on float valve can look OK but on older bikes the rubber can harden and it doesn't seal so well.
Check float height, very important before you start adjusting jetting.
Once you've completed all the above start trying different jets. You said it ran good with your friends carb, try copying his jetting, it might not be perfect but should give you a good starting point.
Main things to concentrate on are... Main Jet, Pilot Jet, Needle and clip position, Air Screw.
Good luck, stick with it. Once you get it jetted correctly it'll be a great ride!
In addition to all the good advice Dave gave you, I feel it is best to have a freshly packed silencer when "critically" jetting a carb. This will remove one uncertainty in your equation.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 09-12-2018, 03:56 AM
SS109's Avatar
SS109 SS109 is offline
The Chinese knock offs just aren't worth it IMO. Their jets are not genuine so their numbering system, if they're even marked, won't match with Keihin jets so jetting them is a pain. Also, one that most seem to overlook whether genuine or not, you need to have the right number slide in there as well.
You can buy a real deal Keihin through Sudco, Jet-r-us, or a nicely modified version from RB Designs (Ron Black).
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Carburetor parts for you Gas Gas Buddmatto General Discussions & Announcements 0 04-20-2017 08:39 AM
Carburetor liamthom Enduro Intake/Carburetion - 2 stroke 9 03-19-2015 02:00 PM
Lectron Carburetor Testing & Adjustment singletracker Pictures & Videos 4 01-12-2013 09:37 AM
balanced carburetor 300ec Enduro Intake/Carburetion - 2 stroke 12 02-21-2012 10:07 AM
