Old 07-08-2018, 10:23 AM
Default The RS125 wheel mystery
So after doing the TZR125 front and GS500 rear SuMo conversion, I eventually decided it was time to get some proper sized wheels and a nice 320mm brake disc. After a bit of a rear on here and the KTM forums, it appears RS125 wheels are the wheel of choice... So what is required to make the buggers fit?
First off, these wheels are from a 2007+ RS125, and are being put on a 2002 EC300.
Front wheel, though the other post states the front wheel requires machining, it does not.
To make fit you require -
2x 25x47x12 bearings
1x 25.1x32(minimum)x78.6mm centre spacer
1x 25.1x32x12 disc side spacer
1x 25.1x32x16 hub side spacer
2x 32x47x7 seals
Adaptor bracket required has 3 holes
Hole 1 - X0Y0 (datum)
Hole 2 - X35Y-2.5
Hole 3 - X51.5Y0
Then it must be milled with 12mm clearance on the holes.
Rear wheel -
Sprocket hub must have 7mm machined off of the disc face, and 6mm off of the hub.
Rear wheel must have 3mm off of the disc face and 3mm off of the hub
Centre spacer remains the same
Disc side spacer 20x32x7mm
Sprocket side spacer (stepped) -
ID 20
OD1 25x18 L
OD2 32x12 L
Then just replace all of the carrier and sprocket bolts with low profile button heads, and off you go !
2016 RM-Z450
Old 07-08-2018, 01:43 PM
(F5) (F5) is online now
S'funny. I've messed around with lots of RS125 wheels and none of them looked like that.
Honda never ran cush drives on their race bikes.
Old 07-08-2018, 06:01 PM
pscook's Avatar
pscook pscook is offline
Likely Aprilia RS125 wheels. The street bike, of course, not the RS125R GP bike.
Phil
(New bike pending...)
Old 07-08-2018, 08:50 PM
Just being silly. A mate has one about that era. Not common here.
Old 07-09-2018, 12:06 AM
So esoteric it burns !!
2016 RM-Z450
Old 07-09-2018, 01:17 PM
Harry's Avatar
Harry Harry is offline
Try and contact WAZ . He has RS wheels shown on this post
http://www.gasgasrider.org/forum/sho...ighlight=super
Old 07-10-2018, 02:29 PM
Mine are on and running mate cheers though!
2016 RM-Z450
2008 FSR 450 mystery electrical connector johnalex Enduro Electrical & Wiring 3 12-08-2016 06:52 PM
Ground location and mystery wire RockefellerGG Enduro Electrical & Wiring 4 12-20-2015 09:03 PM
mystery bike contact United Kingdom 2 08-13-2015 04:09 PM
Mystery solved!! Must read!!! Pinittowinit Enduro Intake/Carburetion - 2 stroke 4 09-09-2013 08:35 AM
Mystery Bolt Killed my bike! gtsnowcrack Enduro Engine - 2 stroke 5 04-04-2007 03:41 PM
