Old 04-17-2018, 05:36 PM
Gibnut Gibnut is offline
That's the AS2, flat cap secured by 2 x m5 bolts.
AS1 is a round internally threaded cap.
Right you are, Jakobi! I had my ASses back to front
Old 06-10-2018, 01:58 AM
Gasser Nate's Avatar
2018 Ec300 0-1000ft
40 pilot NEDW #2 172 main.
Electric smooth power, barely even feel the power valve open. But crack the throttle and it sings nicely pulling through into a crisp strong top end.
Less than 5l for over 58 k?s of tight nasty terrain.
Old 06-29-2018, 02:25 PM
2018 300GP - PWK 38
Temperature (degF) = 68 F to 86 F
Elevation (feet) = 300 to 1000 Feet
Main jet = 176
Pilot jet = 40
Needle & notch = JD Blue, clip 3 from top
Air screw setting = 2 Turns Out
Throttle valve/slide = no clue, sorry
Fuel: 102 Octane with 80:1 (Amsoil Saber Pro) or alternative
Fuel: 95 Octane with 60:1 (Putoline MX9)
Float height: 1mm lower than specified
Spark Plug: NGK BR8EG
FMF pipe and muffler (OEM)
Crankcase vent disconnected from intake boot (like on XC model)
Old 07-09-2018, 09:44 AM
Chris_tian Chris_tian is offline
Hello,
at the moment i try this at my 2018 GP
Temp: hot 25-32c 77-89F
Elevation: 0-300m 0- 1000F
Pilot 40
Main 172
Needle: N1EF
Noth: #2
Slide 9
AS 1,5
It is much better but i think the needle is the problem so i try the NEDW.
Old 07-09-2018, 03:13 PM
Keg Keg is offline
It is really cold here at the moment. Bottom of Australia.
So I thought I would try something different from the NEDW. It was a little lean if I trailed throttle into corners or ran the idle too high.
GP300 2018
300-500m above sea level
5-10 degrees c (40-50f)
N1EH #3
Pj 42
Mj175
As 1 1/4
It starts really easily and is strong and linear through the rev range. I little heavy on fuel, but overall very rideable in cold weather. Stalls a little bit but I haven't checked the float height yet.
EC300 2019 (11 Gassers owned, many more to go)
Old 07-12-2018, 12:30 PM
2006 ec300 - sea level
Pwk38
38p
NECH top clip
168 main
2002 ec300 supermoto
Pwk38
35p
NECH top clip
165 main
Both run I credibly well and haven't seized yet! (The NExx needles are rich at full throttle, hence small mains)
2016 RM-Z450
Old 07-12-2018, 03:42 PM
Gottsell Gottsell is offline
2018 ec 300
Sea level
20-25c
Nedh 3
45
180
Old 08-01-2018, 05:15 AM
Head cut & bowl reshaped (TSP Australia ). Squish now 1.35mm.
42p, 175m, a/s 1.5, NEDW #3, Motul 710 @2% in 98RON.
Quiet, smooth, clean power. No spooge to speak of. More bottom end/mid post-head cut and the bike is liking a 42p now, too.
I?m pretty finicky with jetting set up & this is spot on for the bike, rider & terrain.
Gas Gas 2018 EC250 Six Days - sold
Old 09-17-2018, 11:41 AM
2018 XC 250
Head has been cut for 100 octane race gas.
Temperature: 95 degrees F - 80 degrees F
Elevation: 2000'-7,000'
Pilot: 40
Main: 172
Needle: NEDW 2nd position
A/S: 1.5 out
Moltul 710 @ 50:1
Bike pulls very strong from bottom to top. Noticeable gain in bottom and mid from cut head and power delivery is more linear now. Still getting a good amount of spooge from pipe.
Old 11-29-2018, 02:13 AM
2019 EC300 - PWK 38
Temperature (degF) = 50 F to 86 F
Main jet = 178
Pilot jet = 42
Needle & notch = JD red, clip 3 from top (JD blue on#3 below 50F)
Air screw setting = 2,25 Turns Out
Fuel: 98 Octane with 50:1 Putoline MX9
Float height: 1mm lower than stock
Spark Plug: NGK BR8EIX (iridium)
FMF muffler (OEM)
Crankcase vents disconnected from intake boot (like on XC model)
The jetting database needs your help! MattR General Discussions & Announcements 4 10-18-2017 05:34 PM
JD Jetting settings for linear power delivery? SpeedyManiac Enduro Intake/Carburetion - 2 stroke 5 04-06-2010 06:17 PM
Modification/Aftermarket Database SpeedyManiac Enduro Product Reviews 4 02-04-2009 07:09 AM
Jetting Database Announcement MattR General Discussions & Announcements 0 12-18-2008 08:58 PM
Jetting Database Summary MattR Enduro Intake/Carburetion - 2 stroke 0 12-18-2008 08:36 PM
