Old 06-12-2018, 02:11 PM
(F5)'s Avatar
(F5) (F5) is offline
A mate is running NEDJ (ex RM250) in his 15, 2nd from top and is excellent but our fuel may require slight changes to position, pilot main, from yours.
Float level procedure seems weird until you do it then kinda get a feel for where the float sits , carb on an angle. I cut some cardboard with a slot out of it to set measurement top of float to base of carb. Mine was seriously the other way.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 06-12-2018, 03:34 PM
Oilydub Oilydub is offline
I only had to do a minimum adjustment to the float height. There seems to be no measurements to be had on mine just align the float with the carb body.
The slow jet is blocked & doesn't want to clear (only using nylon to try to clear it as I don't want to damage it). Might just have to get another.
Thanks for the tip on the needle, will probably change it in the future but just need to make sure it runs as well as it did only a couple of weeks ago.
I run it on BP Ultimate (97-99 octane I think).
2015 model EC300 racing
1980 KDX175
1976 KZ900
Old 06-12-2018, 07:55 PM
(F5)'s Avatar
Check the tank. Only a bit of grit or a hair can prop the float jet open.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 06-13-2018, 01:32 AM
Originally Posted by Oilydub View Post
Carb apart, it has the N1EF needle with the clip second from top.
Main jet 175
Pilot 40 but the pilot is blocked !!!!!
Will clean the pilot & the tank as suggested & set the float height.
Don't want to change parts for the sake of it but what needle would be suitable for the future.
Bike only used for racing enduro's, altitide sea level to about 300 metres.
Swazi matt what exactly do you mean by looping the overflow?
Sorry about all the questions, new to Gasgas I usually race a 1980 KDX175 (nice & simple).
have a look at this picture:
https://thumpertalk.com/forums/topic...m-300-xcw-mpg/
2003 txt250 Pro
2013 Ossa 280i
Old 06-13-2018, 02:41 AM
Originally Posted by swazi_matt View Post
Cheers Matt, see what you mean now
1980 KDX175
1976 KZ900
Old 06-13-2018, 11:14 AM
Neil E. Neil E. is offline
Soak the pilot jet in carb cleaner/lacquer thinner/acetone overnight, then blow through with compressed air.
2011 EC250E
Old 06-22-2018, 04:23 AM
Update:
The whole carb was meticulously cleaned as well as the fuel tank/tap/filter.
The bike now has a new pilot jet as the original wouldn't unblock.
The float is set 10 degrees from parallel & doeesn't overflow until about 45 degrees lean (as per the post "float bowl height on 2010 300???").
Looped the overflow "just in case".
All new screws in the carb & a new idle screw that's easier to use.
The air screw is 3.5 turns out & she now rips on part throttle.
I know that is too far out & she will require a new needle & re-jetting in the future but just needed her running properly.
Still a bit smokey but might just be down to the mess in the silencer.
Need to get out on a practice track this weekend then will repack the silencer next week.
Thanks guys for all your advice, its appreciated.
1980 KDX175
1976 KZ900
Old 06-22-2018, 11:14 AM
Update:
The air screw is not affected by the needle. You need a smaller pilot jet
Old 06-22-2018, 11:19 AM
The general consensus on here is that the standard needle is rubbish.
Will completely upgrade the carb in one hit as I know it would benefit from the smaller pilot jet as well.
Just needed to get it running as I have a race in 2 weeks & need to get some practice in first.
Don't want to get bogged down with loads of alterations at the moment.
1980 KDX175
1976 KZ900
2011 Ec450f fuel consumption. brandostevo Enduro Engine 4 stroke (including EFI & Exhaust) 3 05-09-2018 07:27 AM
Smoke! sam097 General Discussions & Announcements 0 02-19-2017 04:57 PM
fuel consumption bonkeye Enduro Intake/Carburetion - 2 stroke 17 03-20-2014 04:03 PM
Jetting help - Fuel consumption Jakobi Enduro Intake/Carburetion - 2 stroke 17 11-12-2010 01:05 AM
gas consumption 200 race pace? stainlesscycle Enduro Engine - 2 stroke 7 02-08-2010 09:11 AM
