Old 08-30-2006, 10:02 PM
MattR's Avatar
MattR MattR is offline
Default FAQ: Gear ratios and sprocket selection
Question:
How do I determine the gear ratio based on my front and rear sprockets?
What sprockets do I use for more torque and better acceleration?
I want more top speed... what sprockets should I change to for road use?
Answer:
The best way to explain gear ratios is to see them in tabular format. As shown below, the same gear ratio can be obtained by several combinations of front and rear sprockets. The gear ratio is calculated by dividing the "rear sprocket number of teeth" by the "front sprocket number of teeth". Lower gear ratios provide more top speed but less torque and acceleration. Whereas, higher gear ratios provide more torque and acceleration but less top speed.
An example is shown below to help interpret the table. It may be seen that a reduction/addition of 1 tooth on the front sprocket is equivalent to approximately 4 teeth on the rear sprocket. It should be noted that smaller front sprockets (such as 12T) can cause more chain wear. While swapping front sprockets may offer convenient setups between road and tight singletrack, this does result in a larger jump. By changing the rear sprocket, fine increments in gear ratio can be obtained with each tooth.
Matt
Current: 2009 Yamaha FZ1
Oil ratios and types gasser Enduro Intake/Carburetion - 2 stroke 9 06-23-2013 06:38 PM
how much gear oil boostedte37 Enduro Engine - 2 stroke 4 04-08-2010 03:13 PM
Gear oil? nick790 Enduro Engine - 2 stroke 7 05-18-2009 06:54 AM
gear problem new gas gas Enduro Engine - 2 stroke 2 01-06-2009 09:53 AM
Springs selection impact on suspension? bergerhag Enduro Suspension 27 06-20-2007 01:58 PM
