Old 08-19-2008, 09:12 AM
Eric K Eric K is offline
Default Dirt Rider test on-line extra
Check out the DR on-line test extra for the GasGas 300...
http://www.dirtrider.com/features/14...ras/index.html
Looking at the endurocross times shows the GasGas does well in the tough riding...
http://www.dirtrider.com/features/14.../photo_19.html
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 08-19-2008, 09:45 AM
gasIdaho gasIdaho is offline
In the DR mag article the GG is listed at 258 lbs with full tank. Alot heavier than I expected.
Old 08-19-2008, 01:43 PM
Skidad's Avatar
Skidad Skidad is offline
That's pretty heavy IMO. It would put it in the range of 237 without gas with no guards etc. Anyone confirm that weight?
Skidad
Old 08-19-2008, 02:28 PM
nhrider's Avatar
nhrider nhrider is offline
Yes, just a little slower than the KTM300 and Christini AWD. The Christini system isn't cheap...
Most of those guys had already ridden the KTM and are use to it. I wonder what would have happened with a little more seat on the GG???
2005 YZ 250F
Old 08-20-2008, 08:26 AM
You can see the GasGas in the DR test pictures has aluminum handguards and skidplate, adding about 5 lbs.
It is disappointing to see the GasGas show up with the added weight penalty of an aluminum skid plate and full wrap aluminum hanguards when the others usually arrive without a skid plate and minimal plastic handguards.
My '06 EC300 brand new out of the crate with the DS stuff (100 watt coil, headlight, tail light, signals, horn, rear fender extension, odo/speedo) no gas, no trans oil weighed 237 lbs.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 08-20-2008, 10:37 AM
Skidad's Avatar
Claimed dry weight FWIW. VERY different from real actual weight I guess. I also assume this is with all the lights and junk because that's the way they're sold every where else in the world and on the GG site pictures.
200 95kg 209.4lbs
250 97kg 213.8lbs
300 98kg 216lbs
I believe one of the Aussie reviews of the 250/300 had it listed at 108kg or 238lbs. That would match Erik K's measurment very closely. Still wish it was another 10lbs or more lighter like the KTM.
Skidad
Old 08-20-2008, 02:42 PM
d2w's Avatar
d2w d2w is offline
Now that's very interesting. Out of boredom I threw the front wheel on a digital bathroom scale and measured 135lbs, and then threw on the rear wheel and measures 144lbs. Can I sum those values to arrive at a staggering 279lbs?!
My bike is fully wet (IMS 14 litre tank), armoured (skid, pipe, hand, front and rear fins, rads, headlight, front fender), auto-clutch, steering damper on a riser, and an EC stator.
Hmmm ... do I need all the armour because I fall? Or do I fall because of all the armour?
Dale
Old 08-20-2008, 04:59 PM
Skidad's Avatar
Dale
Well that's 22lbs of fuel you got there, the tank itself must be a good bit heavier than the stock 9.5 litre tank so add a few more extra lbs for that, maybe 10lbs for all the armor and junk and yeah your getting near the 240 mark. Weight is what makes these things so stable/planted.
An honset to god 210lb KTM 200 sure is looking good to my 50 YO body LOL.
Skidad
Old 12-30-2008, 08:53 PM
Some more 2008 Gas Gas tests.
http://www.gasgas.com.au/21.htm
Old 12-30-2008, 10:45 PM
MattR's Avatar
MattR MattR is offline
Thanks for posting the link. I read the EC250 review... nice compliments. Did you notice the "switchgear" on the handlebar? We call it a headlight switch, but it is an interesting version. Do only the EU and AU bikes get this?
Matt
Current: 2009 Yamaha FZ1
Aaron Wegner to Represent GasGas in 2011 twowheels General Discussions & Announcements 8 10-08-2010 06:13 PM
2011 GasGas Sixdays noobi General Discussions & Announcements 38 09-02-2010 06:06 PM
