Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > Pictures & Videos
Old 09-24-2015, 11:52 PM
Rick's Avatar
Rick Rick is offline
Originally Posted by 12Bravo View Post
Some more pictures, please tell me what you see Good or Bad...I am learning this machine!
The radiator catch tank is missing.......no biggie.
carb vent line doesn't vent to the clutch master cylinder.......
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 09-24-2015, 11:54 PM
Rick's Avatar
I will post the pictures and let you all see what I got and put some input in on it. One thing that has already happened, the front brake stopped working. The lever just flops back and forth and is not connected to anything. It wasn't like that when I test rode it at the guys farm I bought it from. But it is now, after using the front brake to help slow me down coming out of the bed of my truck....I took close up pictures of the issue, maybe you all can point me in the right direction to fix this, I want to ride!
I will post more in the next post, not sure how many I can attach in one post.
Thanks
there is a rubber boot missing by the piston.....keeps muck from getting into the piston area. Should have a new one in rebuild kit.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 09-25-2015, 09:11 AM
12Bravo's Avatar
12Bravo 12Bravo is offline
What goes under the rubber boot and actually hits the lever?
There was a little metal piece that was smashed and bent. When I went to the KTM dealer today, they found a rebuild kit from a 99 200 that would fit and was the same piston. But they didn't know what I was talking about in regards to the lever actually activating the piston. It was like I was talking Chinese to them or something. He didn't seem to happy, I didn't know a part number, nor was he happy I wanted to take KTM parts and put on a Gasgas......Only KTM dealer in this area, so guess I will deal with it or order off line.
I called Hall's also, he is going to look into it and call me back.
Old 09-28-2015, 10:55 AM
12Bravo's Avatar
Ok, this might sound dumb, but I have never heard of a carb venting into a Master Cylinder......
My brand new front brake M/C should be here today. So maybe I will be able to ride this afternoon as long as it bleeds good and is not a pain in the butt to get installed.
Old 09-28-2015, 12:04 PM
Rick's Avatar
Do a search on this site for bleeding brakes, youtube, Motosport Outlet and other sites have "how to" video's...watch them a few times until you get a grasp on the concept of bleeding brakes.
Good luck
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 09-30-2015, 05:49 PM
12Bravo's Avatar
Just an update, a good one at that!
Compression check 95psi.
Changed gear oil, purchased Rotella 5-40 Synthetic for next change.
Cleaned air filter, ordered a new one!
Disassembled and cleaned the carb, that is the easiest carb I have ever worked with!
Put the new reeds in that came with the bike.
New gasket, had to make it, since no one has anything got this reed assembly.
Bled the clutch, still won't idle in gear. Kind of a pain when slowing down to a stop.
New front brake M/C assembly, bled and works well.
Adjusted Handle bars for my ape arms!
Adjusted the shift lever up a bit.
Adjusted rear brake lever up a bit.
Releases air from front shocks, they had some pressure in them for sure.
The best part of the day was the test ride, oh wow.
With all that I did, it have some snap now. It is peepy for sure, yesterday it was sluggish on the take off, had to rev higher to get it to go. Now it just lugs a long just fine. The front end will come up, if I can keep traction. Wheel spins really easily, but I was in a grass field and it was a little wet from the rain about 2 hours ago.
All and all, I'm a happy GG owner now and feel comfortable with the machine mechanically speaking. Me, not so much, it's been a long time since I ripped it up on a bike!
Old 09-30-2015, 11:00 PM
Moto7man Moto7man is offline
The bike looks good, you should be able to set up that ohlins shock fairly easily.
―Comedian Lewis Black
-Unknown Sardaukar
The Gasser iamovru General Discussions & Announcements 57 08-30-2014 12:21 PM
gasser 125 STEVEV General Discussions & Announcements 27 08-07-2012 12:40 PM
New Gasser JustTroItIn General Discussions & Announcements 9 09-16-2010 12:14 AM
yay got another gasser!! mountain thumper General Discussions & Announcements 11 07-19-2009 06:55 PM
