Any short levers available for the Gassers and how do you use your clutch?
My clutch was set-up to start working close to the bar as I keep my outer 2 fingers on the grip and use 2 fingers to pull it. But over tricky terrain sometime I can't pull the clutch in enough and the lever hits my 2 fingers on the bar. I've adjusted the lever furter out but it's still a problem. I heard new KTM's have short levers and that sounds like a nice solution so I could pull the clutch and the lever may not hit the 2 outer fingers on the bar? But does anyone make them?
'05 Gas Gas 300 '97 Aprilia Pegaso 650 '99 KTM 200 '95 ish XR630 (died many times in Oz) |
You can get a shorty clutch lever from your dealer..
"It's Nature that Brings out the Madness" GasGas FSR450 07' |
I just cut mine. Works like a charm.
2004 GasGas DE250 |
i set mine up the same way, and had the same prob, my solution was to mark where your fingers are on the lever, take it off, heat it up in a vise with a torch, then whack it with a rubber mallet till betnt enough to miss my other fingers, and if i need, its still close enough to grab with all four.
Le Crutan 98 ec250 sixdays, doma, eline pipe guard, zokes shivers from a cr250,fredette racing chain slider, protaper withbarkbusters (SOLD) FOR THE SECOND TIME 07 EC300 polisport headlight, acerbis taillight ltr pv cover and case saver,trailtech endurance,120z fww, g2 throttle,xr chain puck: |
Dont your fingers slide off the end?
Any idea how short it is - i think my dealer would have to order it for me.
Not at all. I'm only using 2 fingers to clutch through the tight stuff.
2004 GasGas DE250 |
I cut down as well and it seems to work just fine.
I attach a little skate board grip tape to give it a really sticky grip. It does wear through gloves very quickly though, the down side. |
I been running cut levers for years. When I put bark busters on my drz I had to cut them to get them inside the bark buster. rode like that for 4 yrs never any slip issues. My gasser fell over last year immediately after I put a new clutch lever on and "cut" the lever down to it's satisfaction. haven't bothered replacing it. No slip issues with that either. Be aware that a lot of mx tracks in my area will not let you on the track with cut or boken levers. evidently they consider it a safety thing. gotta have the balls on the ends of the lever. Might want to keep a set of "normal" levers around if you plan on the occasional track day or race. |
Gas Gas trials bikes use the shorty lever and it is a bolt on swap.
I also cut mine down and welded an 'end' on it which I contoured with a file for my own preference and I prefer this 'homemade' lever to the trials one but they are very similar. I only use two fingers on the clutch. |
Short 2010 250 Six Day review | Skidad | Ride Reports | 3 | 03-05-2010 10:42 PM |
jetting for short body PWK..... | haugergaard | Enduro Intake/Carburetion - 2 stroke | 5 | 02-28-2010 12:31 PM |
A short video from Finland | GasGasser | Pictures & Videos | 3 | 10-21-2009 01:28 PM |
Boomhauers Short Lived HS | Boomhauer | Pictures & Videos | 0 | 10-30-2007 08:26 PM |
A short Introduction....Finally | lukachuki | General Discussions & Announcements | 3 | 08-28-2007 07:02 PM |
