Old 09-29-2014, 08:02 PM
Default Small amount of oil in crankcase
I just picked up a brand new to me 05 ec300. I have receipts showing that it had a complete rebuild in May of last year. New bearings, seals, rod, piston and so on. It has had the head done, Lt power valve cover, and so on. I did my first oil change the other day and pulled the crankcase drain plug by mistake and I got a very small amount of oil out of it. Maybe 5 or 6 drops. Anyone else ever have this happen? My first thought is crank seals but it runs way to good to be burning gear oil AMD the gear oil didn't smell like gas. Help?
Old 09-29-2014, 08:13 PM
hamilton's Avatar
hamilton hamilton is offline
Oil in the crankcase is a good thing.
15 GASGAS EC 250
19 Sherco SE 125R
Old 09-29-2014, 08:29 PM
2 strokes tend to like it.
Old 09-29-2014, 08:47 PM
bowhunter007's Avatar
Some even call it lubrication.
Old 09-29-2014, 09:20 PM
Hmm. I guess so but I have never seen oil standing in the crankcase of a 2t. But then again I have never had one with a drain plug in the crankcase
Old 09-30-2014, 10:19 AM
Neil E. Neil E. is online now
Oil will always be present in the crankcase. Oil vapor coats the surfaces as it passes through the engine. Some condenses and sits at the bottom. It never amounts to much quantity as the crank will pick it up and sling it back into mist.
Old 09-30-2014, 10:37 AM
Thanks Neil that's what I was asking
Old 09-30-2014, 10:49 AM
Rick's Avatar
Rick Rick is offline
Talking
Keeps the main bearings rolling smooth!
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 09-30-2014, 10:41 PM
thumperflipper thumperflipper is offline
Memphis2857, I think you and Neil (and everyone above) are right about your assessment... last year I had black transmission oil at every oil change, losing trans oil (put 900 in, got 700 out when drained at oil change time), exhaust spooge all over, and running rich. And yes vacuum from piston going up was pulling trans oil into the crankcase, and I would drain a small amt of trans oil out at each oil change, maybe a few cc's. These are symptoms of leaking R side crank seal (and maybe main case seal?). Changed the right hand crank seal and viola, trans oil clean now, no volume loss at oil changes, and nasty spooging gone, running much cleaner since then...
07 GG EC300
11 GG EC300E
WEC Line-up: Good amount of Gassers! firffighter General Discussions & Announcements 3 03-17-2012 12:33 PM
Coolant in crankcase = no fun stainlesscycle Enduro Engine - 2 stroke 35 02-02-2012 09:59 AM
Crankcase Seal Removal gasser Enduro Engine - 2 stroke 4 10-06-2009 12:47 PM
Crankcase vent blocked kendunn Enduro Engine - 2 stroke 2 10-06-2009 12:37 PM
Crankcase steam hose Alan Enduro Engine 4 stroke (including EFI & Exhaust) 8 07-06-2007 10:15 PM
