Old 07-07-2009, 10:56 PM
roostafish's Avatar
Default Suggestions on removing swingarm
My swingarm bolt is siezed to the bushings, heat doesn't seem to phase it, hitting it with a 3 lb sledge and a brass drift does nothing but make noise. I squirted WD 40 in all the joints and am waiting. Maybe I need a bigger torch!
Mike Sheetz
OMRA #21AA
'15 KTM 300 XC-W
Gran Prix Cycle
LTR Suspension
RB-Designs
Old 07-08-2009, 04:29 AM
rpduc rpduc is offline
This might be helpful...
http://www.gasgasrider.org/forum/sho...rm+axle+puller
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
'06 Duc S2r 1000 R.I.P
May be so... May be not so...
My Website
Old 07-08-2009, 09:53 AM
Rick's Avatar
Rick Rick is offline
Roost....loosen the motor mount bolts...worth a try.
Good luck
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 07-08-2009, 11:28 AM
The problem with heat is you can't get it where you need it. So, try cold instead. I know LN2 is beyond the reach of most but dry ice is common. Try packing the hollow of the shaft with dry ice and deep freezing it before you hit it with a hammer. The shaft should contract more than the sleeves. I have removed several frozen bearings from steering stems this way, one just fell off with a tap on the bench. I never had a swingarm seize to try it but its worth a try.
Old 07-08-2009, 01:13 PM
Nick's Avatar
Nick Nick is offline
Go find some Kroil. You can get it at gun shops. Best penetrating oil there is. WD is worthless except as a solvent for cleaning.
Old 07-08-2009, 08:52 PM
roostafish's Avatar
I soaked it in Maltby penetrant. Then hit it with an air hammer. I didn't even try smacking it after the lube, but with the motor mounts loosened, and one shot with the air hammer, it shot out the other side like a bullet from a gun. My white cabinet in the garage now has a bruise from it! Yikes. I guess it wasn't that stuck. The grease looks good, and even the grease on the swingarm bolt was slippery. I think the biggest deal was loosening the motor mounts.
A lesson well learned.
I have a complaint though. Why so many silly different sizes of bolts???????? Geez, 16,17,18,22mm. All on the linkage. My one complaint with Gas Gas from the very beginning is that it's not a mechanic friendly bike. Wonderful to ride, "what were you thinking" to wrench on. I suppose after owning a Husky, anything is a pain to wrench on, that bike was made with the mechanic in mind.
Mike Sheetz
OMRA #21AA
'15 KTM 300 XC-W
Gran Prix Cycle
LTR Suspension
RB-Designs
Old 07-09-2009, 12:20 AM
TooFastTim TooFastTim is offline
Mutter mutter..curse curse..
TooFastTim
'06 Raga Rep
(hopefully '08 EC200 & '10 TXT Pro 250 soon)
Old 07-09-2009, 07:17 AM
jostby jostby is offline
Us proffessional mechanics have a dream (and we mutter it often).... That engineers will spend all eternity wrenching on their own ideas in the afterlife
'00 XC250 (mine)
'04 EC250 (the kids)
Old 07-09-2009, 07:49 AM
webmaster's Avatar
Administrator
One advantage of having a factory trained honda master tech as your best friend -> Les at LT-Racing disassembled that bike and lubed everything for me before it was even ridden. That grease on there was from that prep. If he hadn't have done this - you might have had a little bit harder time with it...
And yes, he did the same for an '08 husky txc510 we purchased and there was much less cussing involved...
Webmaster
GasGas Riders Club
Old 10-03-2009, 07:31 PM
309stanley 309stanley is offline
Soak with PB Blaster then use a air hammer with a punch stlye bit.
need a new air filter any suggestions.... dareuk Enduro Product Reviews 4 03-24-2010 03:05 PM
First enduro ever...tips/suggestions? sled_fiend Off Road Racer's Corner 8 07-10-2009 08:55 AM
EC Chain/Sprocket Suggestions? cdn280 General Discussions & Announcements 10 07-31-2008 02:22 PM
New DP clutch plates won't fit - suggestions? stay_upright Enduro Engine - 2 stroke 6 05-26-2008 09:59 AM
Removing the fork cap? sanderjavant Enduro Suspension 4 07-22-2007 11:35 AM
