Old 05-06-2007, 06:43 AM
colinmc400 colinmc400 is offline
Default 06 300EC first ride impressions on 1st and 2nd gear.
Got my first ride on my year old 300EC yesterday. Overall i can safely say "why the hell didn't i do this before" We ran 2 @40 mile loops in fairly tight forest going. 3rd and 4th gears were a total revelation, as they were faultless and covered lots of what i needed. 1st gear was almost redundant, but 2nd was needed.
Both 1st and 2nd felt a bit "wooly and fluffy" at just a wiff of throttle opening and were not as precise as i would like for the really technical going, but cleaned up once the throttle was opened up. So i am thinking pilot too rich maybe?
It was @the mid 60's yesterday and a little humid. We were at maybe 500ft above sea level. I have been assured all the carb settings are stock. I ran it with BP98ron fuel and 40:1 Silkolene fully synth.
I do not want to mess with how the bike felt in 3rd and 4th, but would like to tidy up first and second. Any ideas on what my base settings should be? Please be gentle, i am a no-hope on jetting and all things carb related
Old 05-06-2007, 10:37 AM
widebear's Avatar
widebear widebear is offline
Banned
Colin. It has been my experiance that there are no standard gasgas settings. You will have to remove the needle and slide and the two jets in order to understand fully what is going on . All of these components must be in sync to work properly and only then can you fine tune to get the desired results. Also i vigoursly reject any assertions that a certain wonder component will save the day , this is just plain wrong and ammounts to nothing more than biased and self interested product promotion. Let us know what you have in there and I promise the good people on this forum will help you achive your goals in the most entertaining and contentious manner.
Old 05-06-2007, 08:09 PM
Ok that seems entirely fair. I will get the carb off and see whats in there and check what position the air screw is in and go from there.
Old 05-07-2007, 07:10 AM
GMP's Avatar
GMP GMP is offline
While its off, check if the float is twisted and at the proper level, and the condition of the reeds.
Yes, there is no "magic"one size fits all jetting kit, Les himself will tell you that. Its just a better starting point in most cases. I just set up my '07 with what I thought would be rich for break in and it was spot on crisp. There all different.
Old 05-08-2007, 04:00 AM
iancp5's Avatar
iancp5 iancp5 is offline
Some people are up in the 48's on the pilot while I am running a 35! So you can see how big the variation is. For reference I am setup as follows but as said you have to plot your own course on this one to get the best:-
35 pilot
#N1EF needle on 2nd clip
178 main
#7 slide
50:1 oil, high quality pump gas
I find the LTR needle, not sure which one I have, maybe the "0", works well on 2nd clip as well, probably cleaner as well but I get a slightly gentler transition from the N1EF needle. Idle is ok but not wonderful, never seen a Gasser with perfect idle but some say it is possible with a #9 slide. I also think our gas / petrol / fuel is more consistent in the UK. Most UK guys agree on jetting but there seems to be a wide variation in the US even at similar altitudes.
Old 05-08-2007, 09:05 AM
35 pilot
178 main
#7 slide
Is that Ian Packer lurking over there? Its Colin McCaughey here Ian living in sunny Aus, how goes it? You still got your 300 then?
I finally saw the light and bought a Spaniard. Its really nice, but not quite so sorted as my 250EXC in the really low revs in 1st and 2nd. BP do a 98ron fuel here in Aus and i have been using that, which might muck things up. I am going to have a play with mixtures and air screws this weekend and see if that helps.
See ya!
Old 05-09-2007, 05:26 AM
wise old man wise old man is offline
Colin I'm in Aus. too and my 07 ec300 runs 42 pilot and 170 main with an LTR needle centre clip running BP 98 ron with 40-1 oil mix. Most of the GGs in this area run similar jetting sometimes going to a 40 pilot if running the standard N1EF needle. Just as you discribe my bike also ran pretty rough down low with the standard jetting but now runs very sweetly with the above combination. Andrew
Old 05-09-2007, 07:05 AM
Thanks Andrew, where abouts are you, just to compare temps and altitudes? I am in Perth, so its mostly sea level stuff and fairly low humidity. Not fussed if it doesn;t run so good in summer, as i will be tucked away in the a/c somewhere indoors
Old 05-09-2007, 04:42 PM
Colin I'm in Cairns so yes we do have more humidity than Perth mainly riding sea level to 1000ft above. One thing I did notice just by putting the LTR needle in the bottom end cleaned up even with the standard jetting left in place. Must be something to do with the taper of the needle. Good luck it should be easy to fix with a few jets. And enjoy the ride.
Old 05-10-2007, 07:34 AM
iancp5's Avatar
See ya!
Hi Colin,
Good thanks but a bit limited by a broken finger at the moment. Should be all ok for the Welsh I'm hoping. How are you?
They have their quirks but the Gassers get to you. They just seem that bit easier to manage than other bikes but have lacked the KTM attention to detail. I'm considering stepping down to a 200 sometime. I seem to be doing mostly tight woods events and a 300 is just overkill. Can't make up my mind if I want to move the KTM 450 down to a 250 4T. Might be better to do that and keep the 300 for the more open stuff. I marshalled at Bagshot test ground recently and even when I tried a fast lap I don't think I got past 1/4 throttle on the 450. Well you know what it's like round here and the SEEC events. So the dilemma is 200 2T or 250 4T.
Demo ride impressions rancero86 Ride Reports 2 05-25-2010 07:23 AM
08 ec300. First impressions. cvl05 Enduro Product Reviews 5 07-27-2009 09:19 PM
Gear oil? nick790 Enduro Engine - 2 stroke 7 05-18-2009 06:54 AM
Impressions of the '08 EC200, EC300 and FSR450 bergerhag Ride Reports 3 04-28-2008 05:01 PM
'02 300ec Bultaco206 General Discussions & Announcements 2 01-23-2007 06:40 PM
