#31
If it got hot enough to change color I would check the cyl as well.
lankydoug, Your example is exactly what happened to our GG XC125, except the pressure would blow the cap even before the bike got hot, and there were traces of oil in the coolant. Compression/combustion pressure is a lot higher than cooling system pressure especially when the bike is cold, thats why its likely in this case the oring is an effect not a cause. |
#32
yeah, i had assumed the nikasil was blown - i didn't even look at it - just set it aside for cleaning/inspection later.
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com ![]() |
#33
![]() Quote:
Ken 931-498-5113 |
#34
don't need a top end - have one with just a few hours on it.
crank builder said crank lobes were out by .008" and spacers showed wear (which i know is not common on other cranks - not sure if it's a common gg trait....) . pin was good, but bearing had some wear. i noticed a bit of a groove on ignition side where seal rides. hopefully i can position new seal in better location. i wonder if the play in the 2 piece bearing had anything to do with the groove, or if the lobes being out was my vibration i was chasing. builder also said crank DEFINITELY had some hours on it. although the rod felt fine, i'm glad i rebuilt it - at least i know what's in there now. with a regular bearing in there and newly built crank, hopefully the vibes will go down.
#35
How much more would it be to have the crank balanced, if your builder can do it?
#36
The .008" runout is the source of your vibration. The crank has to run true before you look at balance problems. A properly assembled crank will have less than .001" runout. The crank seal will groove the shaft if it has high hours.
2011 EC250E |
Thread Tools | |
Display Modes | |
white gunk coming from crankcase breather tube | Crankin04 | Enduro Engine 4 stroke (including EFI & Exhaust) | 22 | 07-18-2010 09:58 AM |
Crankcase Seal Removal | gasser | Enduro Engine - 2 stroke | 4 | 10-06-2009 12:47 PM |
Crankcase vent blocked | kendunn | Enduro Engine - 2 stroke | 2 | 10-06-2009 12:37 PM |
Cylinder to Crankcase Gasket order? | Skele | Enduro Engine - 2 stroke | 1 | 08-16-2009 04:40 AM |
Crankcase steam hose | Alan | Enduro Engine 4 stroke (including EFI & Exhaust) | 8 | 07-06-2007 10:15 PM |
