Old 07-10-2014, 02:03 AM
stabak's Avatar
stabak stabak is offline
Default Cylinder removal on a 2013?
We were trying to remove the cylinder yesterday out of an ec 250 2013 and we had to lift up the whole engine just a bit enough to clear the cylinder from the frame (the reinforced part). Not much but we had to remove the front and bottom engine bolts and jack it up .
Is that the normal procedure on the new frame? just checking
Old 07-10-2014, 12:28 PM
djroggen's Avatar
djroggen djroggen is offline
No that is not normal procedure. I did it with only removing the head to clear the frame. I did have to also take the exhaust flange off as well.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Old 07-10-2014, 03:37 PM
VxZeroKnots's Avatar
VxZeroKnots VxZeroKnots is offline
And the CDI too.
Old 07-10-2014, 05:04 PM
This isn't what I wanted to hear. It was pain in the ass enough having to remove the lower rad bolts on the 2011 and earlier models.
Sounds like it'll be almost as easy just to pull the whole engine.
Old 07-10-2014, 05:44 PM
adddy's Avatar
adddy adddy is offline
Hope the replacement cylinder o rings are the correct size....check asap...as i had the wrong ones posted twice from one dealer then wrong from a second dealer, it wasn't until i told GGUK to check there stock by taking a cylinder to the stores did i get the correct fitting part....GGUK had been sent an incorrect sized part with the right part number & passed them out to GG dealers...cost me alot of time
2013 Ossa 300 Enduro Reverse Cylinder Moto7man All Other Bikes... 20 05-16-2012 12:33 AM
Key Removal arminhammer Enduro Electrical & Wiring 11 11-07-2011 07:14 PM
Cylinder Removal? mcnut Enduro Engine - 2 stroke 24 09-29-2011 07:36 PM
Carb Removal carlg Enduro Intake/Carburetion - 2 stroke 13 02-03-2010 03:15 AM
Cylinder removal question: FFRDave Enduro Engine - 2 stroke 9 11-04-2007 12:19 PM
