Old 04-23-2018, 10:48 PM
Gibnut Gibnut is offline
Default 2018 KYB shim stacks
Hi, has anyone had their '18 fork apart & if so, what did you find inside shims-wise, particularly comp valve stack?
Old 04-24-2018, 04:14 AM
Time to be a pioneer gibnut!
Old 04-24-2018, 06:43 AM
Gasser Nate's Avatar
Hahaha you?ve been told Gibson! I expect a report by mid morning!
Old 04-24-2018, 10:46 AM
You find the compression needs to be softened up? I’m running 2 clicks in from full soft and it still deflects on low speed rocks really bad
Old 04-24-2018, 01:48 PM
How about spring rates? I am running .44 spring rate in the KYB's on my 2011 250. When I do an oil change on the 2018 forks I am going to swap one of the .42 springs for a .46. .42 stock seems like a pretty light spring rate unless you are a very light or slow rider. Just my 2 cents.
I personally do not want to start re-valving until I have the spring rates correct and then I will work with the compression and rebound adjustments. My initial impression is that the stock valving is very close for my conditions, which vary from fast rocky to slow technical rocky (Arizona).
Old 04-24-2018, 01:59 PM
I am also interested to see what the oil volume is in the outer chamber. I am running 300cc in my 2011 and that seems to help with plushness on the lower speed stuff...
Old 04-25-2018, 01:39 AM
anyone know if the GG kyb's are the same as the yz kyb's in relation to caliper mounts, axle sizes etc?
(basically asking if you could just swop a yz front end into the 18GG?)
2003 txt250 Pro
2013 Ossa 280i
Old 04-25-2018, 03:39 AM
Anders's Avatar
Anders Anders is offline
For what it's worth; I have been told that a 17 GG fork (hence almost any 48mm GG fork) will fit the 2018 triples and vice versa. But I have no real knowledge in the matter, I haven't tried, not even measured.
But in a week or two, I will have my mate's 2018 in my workshop for tire change, I presume. Then I could take some measurements and compare them to my 2015. If that is of any interest.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 04-25-2018, 09:14 AM
Won’t work. The lugs are different on the bottom.
Old 04-25-2018, 02:17 PM
twowheels's Avatar
Originally Posted by memphis2857 View Post
You find the compression needs to be softened up? I?m running 2 clicks in from full soft and it still deflects on low speed rocks really bad
You might want to try increasing the rebound damping to combat the deflection.
Steven Beane #275
afterhourscycle.com
Sachs shim 7ID & 9ID, where I can buy? dewenduro Enduro Suspension 11 08-15-2016 02:34 PM
Marzocchi 48 shim stack profile. Barbs Enduro Suspension 17 02-29-2016 07:12 AM
Marzocchi 45 shim advice? motopsycho87 Enduro Suspension 17 10-20-2014 12:47 PM
Countershaft sprocket shim 3hunerd Enduro Engine - 2 stroke 5 03-24-2012 09:29 AM
45mm zoke shim id Ed Ventura Enduro Suspension 1 09-22-2008 05:34 AM
