#11
The same V2M05 is used on the Husky CR/WR 250 OEM. The new Huskys may have gone to the VF3 but there should be plenty of VF2s around in parts stock or possibly available for trade.
We recently modified my brothers Husky WR250 with VF2 reeds in low tension position, RBD head mods, and a Keihin PWK 38AS to replace the Mikuini. Bike runs real strong, much more off the bottom. |
#12
Replacement reeds
Dusting off an old thread. Can anyone give me the part # for the replacement petals for the VForce 3. Is it the Honda 250? What year. Thanks.
Below is the part #'s from all the petals on their website. 3P352H - 3P352M - 3P411H - 3P412H - 3P412M - 3P472H - 3P522M - 3P602H - 3P682H - 3P682M - 3P683A - 3P683M - 3P794A - 3P883A -
2008 KTM 300xc Plated |
#13
i have a 2002 EC250 and have the boyesen reed block i have just bought some boyesen pro series dual stage reeds to put in there. standard were the power reeds. i am looking for mid/top end pull, was this the best option ? is there anything else i should have instead to give me mid/top end pull. thanks
2001 Gas Gas EC250 Supermoto Boyesen Pro Series Reeds, Messico & Modified FMF TC II, Black Powdercoated Wheels & Hubs, Red Renthal Fatbars, Polisport Handguards, 4 POT Brembo Front Brake W/ Floating Rotor Want: Doma,Messico Or 06 GG Front Pipe, RB Carb & Head Mod, DE250, XC250 Or EC200 CDI (If you have any of these parts PM me!) |
#14
Yes- Like Kent said, look on ebay for a CR250 1990-2001 ?? V-Force II
Also was available for the Honda Quad 250 I think its a TRX 250, (but you have to file off a bit of the side of it from the Quad one. I did. Fits perfectly.) Did not notice huge gains on the 300...... Jeff 2001 XC300 |
#15
Does anyone know where you can still get replacement reed petals for the Vforce 2 reed cage?
#16
You need to set the reed tension at low on the VF2 to enjoy its full benefits. Even the slightest adjustment away from the low tension setting will make the VF2 perform similar to the VF3.
Kent A |
#17
Is tension adjustment a matter of moving the bar on the outside of the reed cage? (i.e. moving the bar farther from the reed tips creates lower tension)
Gas Gas 125 power valves | geoffg | Enduro Engine - 2 stroke | 8 | 10-28-2010 01:23 PM |
after market base valves 45/50mm marzocchi | armyoforange | Enduro Product Announcements | 9 | 01-23-2010 10:58 PM |
Reed Advice PLEASE | jriley43 | Enduro Intake/Carburetion - 2 stroke | 1 | 05-19-2009 07:50 AM |
Snapped valves on 02 400 | douglase1983 | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 01-10-2009 01:33 PM |
reed spacer? | moff747 | Enduro Intake/Carburetion - 2 stroke | 2 | 02-26-2008 10:26 PM |
