Old 03-22-2010, 07:40 AM
SideshowBob SideshowBob is offline
Default Checking for proper power valve operation 2003 EC250
My EC250 seems to be too snappy. Sluggish bottom, then ripping top end. I am thinking I may have a power valve issue as jetting hasn't made any real difference in how the power hits. My MC250 was much smoother from the bottom up (differences include the 5mm carb spacer and FMF versus the Messico on the EC)
In another post I saw someone suggest taking the right side power valve cover off then starting the bike and revving it to see if the power valve is actuating. This a good idea? Any other suggestions?
Links for my own reference-
http://www.gasgasrider.org/forum/showthread.php?t=4446
2003 EC250 w/ Ohlins pkg
Sometimes you eat the bear, sometimes the bear eats you.
Old 03-22-2010, 07:49 AM
stainlesscycle's Avatar
that's how i checked mine... remove pipe and right pv cover. reinstall pipe. start it up and watch it open/close. you can preload the pv rod to change how it opens a bit...
Old 03-23-2010, 05:55 AM
Thanks, was working fine, a little slow to return maybe. Off to checking other things.
Old 04-07-2010, 08:12 AM
proelton proelton is offline
I have the same problem on my ec 125.
Low end is very poor and when the valve opens it opens to fast, and also it opens when its reving too high. I have to slip the cluch all the time. This was not happening before,
what could it be?
Elton
Old 04-08-2010, 01:00 PM
mxdj2003 mxdj2003 is offline
my powervalve was notchy feeling when i opened it by hand because the bearings had carbon build up on them , i replaced all the bearings with sealed ones and after a season of riding it still opens smooth as silk.
Thread Tools
Display Modes
LTR Power valve cover skid jackson Enduro Product Reviews 22 09-04-2017 02:42 PM
EC125 Power Valve and Oil oldschool07 Enduro Engine - 2 stroke 11 09-27-2015 02:34 PM
Power Valve Cleaning lordfeyr Enduro Engine - 2 stroke 2 01-24-2010 05:07 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
Power Valve rebuild Gas Stu Enduro Engine - 2 stroke 2 09-19-2007 12:38 AM
