Old 02-18-2018, 10:41 PM
BLD's Avatar
BLD BLD is offline
Default Best method to bend shift lever
I?m done with this factory shift lever placement on my ?13 XC 300. One tooth placement either way and it?s too high or too low for me. I?m looking for the Goldilocks solution and have a spare shift lever that came with my bike. Can I use a Mapp (spelling?) gas torch or similar method to bend the old shift lever into a custom position for my giant foot??? Never tried anything like this but I understand that heat may help (seems like aluminum and I?m only familiar with steel which needs heat treatment and annealing after)... I was riding real hard today and the constant missed shifts were the only complaint I have with the bike. Otherwise it is a true high speed mule!
Thanks
Old 02-19-2018, 03:51 AM
m.nowak's Avatar
m.nowak m.nowak is offline
I always use my map torch when I need to bend the levers. Just heat and bend carefully 😊
//Mattias in Sweden
Gasgas EC300
Old 02-19-2018, 07:06 PM
I have had the same problem on several bikes. Take it off the bike before you bend it. It goes easier if you put it in a vice. You might want to quench it in water when you are finished to try to retain some of the strength.
Old 02-19-2018, 10:54 PM
BLD's Avatar
BLD BLD is offline
Thank you. I?ll grab a torch and try on the old beat up one first.
Yes, with steel you want to dunk in water or motor oil while red hot. That will heat treat but be brittle until you anneal (heat up until bluish, can?t remember if you dunk again or let air cool...).
Either way I?ve never tried it with aluminum. I?d hate to snap it off first ride after finding the sweet spot!
997 bend? john r b Enduro Chassis & Body 1 12-29-2015 12:21 AM
Recommended method for cleaning cylinder and PV mwinschel Enduro Engine - 2 stroke 3 11-30-2015 12:47 PM
odi cft honda/kawi bend (renthal 997 bend) Simmo737 Enduro Product Reviews 0 07-30-2013 04:15 AM
2000 XC250 spring arm to shift cam assembly method 70455 Enduro Engine - 2 stroke 0 12-18-2012 07:38 PM
Looking for the rear brake lever replacement and Gear Lever?? Scar13 Enduro Chassis & Body 11 03-12-2012 03:15 PM
