Old 12-01-2017, 11:35 AM
adriano.ro adriano.ro is offline
Default Richer jetting after squish more?
I don't know if where is the best place to ask this question because is about a KTM .
Is about a KM EXC 250 2011 sxs pipe.
I have set squish to 1.45mm. Jetting 42p N3CJ@4 170main as 1 . Alt 700m temp around 5C.
Bike rips! Wheelie at 90kmh. But I feel a bit to lean on bottom. Can I use 45? Isn't to big? Can I go up on main too? I just want to stay a bit richer.
Old 12-01-2017, 04:39 PM
Honestly you need to try each change one at a time an see if it works better than what you have.
Old 12-01-2017, 06:14 PM
Wind the idle mixture screw in. Is it better or worse?
1.45 is still loose as, but often if you go closer the compression will be way high without taking out of the chamber.
Old 12-01-2017, 07:36 PM
1.45mm is just a safe zone. I don't have any tunner in country to make the job properly. Squish was 2.1mm
Old 12-27-2017, 01:17 PM
One question: if i use 45 nedw#3 168 (bike run ok,good bottom,good mid and top but too linear for my taste) and I want to use N3CW witch are the adjustment to do ? Bigger main?
Also I feel a bit of hesitation from 1/2 throttle to work on quick open,can be the main jet? Is flat just before power valve is opening after that booooom. In higher gears it feels the moist.
One more: if I use nedw#3 on and I put on necj#4 how the bike will feel?
Tnx guys. Best forum with very nice people.
05 ec200 squish, cc's, jetting Zrt1200 Enduro Engine - 2 stroke 14 05-21-2016 04:12 PM
Jetting, S3 heads, Squish band, and other fun stuff! memphis2857 Enduro Engine - 2 stroke 5 07-31-2015 04:15 AM
EC300 - Richer needle = less spooge? mtnmanseth Enduro Intake/Carburetion - 2 stroke 3 05-21-2014 11:22 PM
What needle is half clip richer than N3CJ ? mariogt Enduro Intake/Carburetion - 2 stroke 3 12-09-2012 04:04 PM
2011 GG 300 SD squish, comp, and jetting data Sixdays Enduro Engine - 2 stroke 50 04-02-2012 07:17 PM
