Old 02-20-2015, 10:25 PM
earlystock earlystock is offline
Default 2014 xc300
I have lost spark after cleaning the contact on the electric start. Nothing else was touched, had it running 15 minutes prior and used the key to turn it off. I have tried disconnecting the yellow/white wire and still no spark, so now I'm lost. Any ideas?
Old 02-21-2015, 11:38 AM
Neil E. Neil E. is offline
Just in case it's an ignition switch problem, pull the connector off from the switch. If the ignition switch was holding the ground circuit closed, now it will be open for sure. You should get a spark when kicking it over.
2011 EC250E
Old 02-21-2015, 02:59 PM
I will give it a try, didn't think about the key shorting the ignition for some reason lol, must of just been to tired.
Old 02-22-2015, 10:10 PM
Key isn't the problem either, do you think the coil could have just quit? Is there any way of testing to see if it is getting signal without replacing it?
Old 02-23-2015, 11:33 AM
Specify what is "cleaning the contact on the electric start". If you took the solenoid apart, you might have damaged one of the tiny solenoid relay coil wires. It's most likely directly related to the work you did. Take pictures of the part you worked on and post them here. Did you move any wires to do the work?
Does the engine crank OK when you push the start button? Did you test the fuses with a multimeter? If your spark plug is really oily it will be harder to see the spark.
2011 EC250E
Old 02-24-2015, 03:17 AM
I cleaned the contacts on the buttons on the handle bars, I haven't touched the starter itself, and put a new plug in that hasn't even touched fuel yet, still no spark. I checked the two fuses under the seat, is there any more that I don't know of? I know it had to be tied into something I did, but I can't make any sense of it. The starter has never gave me issues, last race I fell in some silt and the button was intermittent because of dirt inside not letting it make contact. Being color blind makes it hard for me to do any wiring so it is not my strong suite. I usually have to have my wife find the right wires for me lol.
Old 02-24-2015, 06:40 AM
possibly a dud spark plug? put the old one back in and try again
(or are you saying you have just put in a new one in an attempt to sort out the problems?)
2003 txt250 Pro
2013 Ossa 280i
Old 02-24-2015, 10:17 AM
A coil usually doesn't go bad so quickly. You get some erratic operation first, like poor firing at high rpm. Unbolt the coil and make sure the frame is clean and free of paint at the attaching point. It needs a good ground.
If you are talking about cleaning the stock Leonelli switch, it has several functions all jammed together in the small housing. It is most likely you disturbed the contact shoe for the kill button and it's shorting the ignition constantly. You should be able to unhook all the connectors from the multi-function switch, then test for spark by kicking the engine over.
One other thing after testing the rest, is to unscrew the spark plug cap from the wire, cut the wire back a 1/4", then screw it back on. This would provide a good connection if the original connection was iffy.
2011 EC250E
Old 02-24-2015, 07:11 PM
I tried the new plug to see if the other plug did get fouled when I couldn't get spark. I have disconnected the key and kill switch to see if that would solve the problem with no change. Can try to cut the plug wire back but can't believe that is the issue sense I never had any problem with the bike prior to this. The start button was the only issue I have had. But now I'm stumped. If I put a multi meter on the coil hot lead I should get a reading correct? Haven't tried it yet sense I haven't pulled the tank yet because I have to remove the steering stabilizer to lift the tank off.
Old 02-26-2015, 01:12 PM
There are multiple parts to the ignition:
1) the separate stator winding that powers the CDI
2) the pickup unit outside of the flywheel that triggers the CDI
3) the CDI itself
4) the coil
5) the spark plug
6) the wiring
I'd still bet it has to do with your CDI being grounded due to your switch cleaning work. You should be able to test the kill switch using a multimeter on continuity setting. It should read zero or very low ohms with the button pressed, then go to infinity when released.
Another test would be to figure out which CDI pin gets grounded to stop the motor. With the CDI disconnected, check continuity between that pin wire and ground. If there is conitinuity, your CDI is being grounded somehow.
You should be able to download a manual with a wiring diagram. That would help you figure out the CDI pins.
2011 EC250E
2013 or 2014 xc300? earlystock General Discussions & Announcements 21 04-19-2014 02:36 AM
2000 xc300 Jeremyxc300 Used Bikes 1 03-17-2014 06:37 PM
2014 XC300-e just arrived!! rosco New Bikes 25 01-12-2014 05:26 PM
