Old 01-09-2017, 03:32 AM
VilluEST VilluEST is offline
2014 EC250ER with AS2 on sea level from -10C to 28C:
182 main, 42 pilot, N3CJ on 3'rd clip, slide #7
Need to adjust air screw for winter-summer temp differences (technical trail riding - low rpm's). Haven't done ice track, but I suppose that needs raising the needle.
Old 06-23-2017, 09:14 PM
lneil06 lneil06 is offline
Originally Posted by Rod Overstreet View Post
2015 EC300
Pilot- 40
Main- 175
AS- 1&1/2 turns out
Needle- JD RED, 3rd clip
Slide- #8
Premix- 50:1 Sprectro
Result...perfection.
What kind of mileage are you getting ?
Lenny
Old 10-01-2017, 03:20 AM
Davehuge's Avatar
Davehuge Davehuge is offline
Default N1EG works great for me!
Bike year & model = EC300 2004 with PWK38 AS1
Temperature (degF) = 60F to 90F
Elevation (feet) = 0 to 3000 Feet
Main jet = 170
Pilot jet = 38
Needle & notch = N1EG Notch 1 (leanest)
Air screw setting = 1 Turn Out
Throttle valve/slide = 7
Results:
Starts easy, idles nice, clean and crisp straight from idle to all throttle positions, pulls hard. Very pleased with it.
Running on 98 Octane Unleaded.
Ipone Samourai 100% Synthectic or Motorex Power Cross 100% Synthetic both at 2% (50:1)
I read a lot of negative comments about the N1EG needle but it works great for me. Maybe I've just dropped lucky and the N1EG suits my carb/bike.
One thing I noticed is it's very sensitive to clip position. On notch 4 it won't start properly, keeps wetting the plug. At notch 3 and 2 it won't pull cleanly at 50% to 75% throttle. At notch 1 it works great.
Thanks to MattR for setting up this thread, very useful.
Old 10-01-2017, 10:27 AM
Archibald Archibald is offline
Default 2001 xc 300
2001 xc 300 PWK 38
Elevation (feet) = 6500 to 11,000 Feet
Main jet = 165
Pilot jet = 35
Needle & notch = CEL needle at clip 2
Air screw setting = 2 Turns Out
Fuel: 87 octane premixed between 50 and 60:1
Has the larger Checkpoint Offroad PV cover and FMF Gnarly pipe.
Results:
Old 10-03-2017, 02:35 AM
Installed slide #6 in May just before enduro trip to Poland and WOW!!! Much stronger pull on low RPM, it's almost like a 300 now.
Old 10-19-2017, 12:15 AM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Main jet = 170
Pilot jet = 38
Results:
Have you tried the RB Designs head mod? It's well worth the money in fuel mileage alone, and it makes throttle response much more crisp.
My riding elevations are very similar to yours.
In my 2006 DE300 with the AS1 carb, my favorite settings are:
Main jet summer-175 winter-178 (If there are going to be long wfo straights in a hare scramble I always run the 178)
Needle - N1EG with clip in second groove from the top
pilot jet - 42 (best idle for my bike. 45 gave stronger/harder mx style starts, but loaded up and fouled plugs while working trail during the summer in the "low" mountains of Arkansas. I think it was because of extended idling and so much trailing throttle going down long downhills. With the 42 pilot it didn't load up, and only spooged out the exhaust just a little bit.)
Slide - 7
I mix non-ethanol 93 octane premium pump gas mixed with Amsoil Dominator at 42/1 (16oz per gallon) (A "ring wear text" showed me that the extra oil gave me better ring wear than 50/1, and the extra oil makes my carb settings slightly leaner.)
My 2006 came with the MotoTasarini V-Force reed block and reeds. (first year for them)
Regarding the RB Designs:
I asked Ron to do the mod to increase my mileage on my 2006 DE300.
After the first ride in the mountains, I came home and added a 10oz flywheel weight. The change in throttle response had the rear end of the bike coming around even with the front in rocky off-camber turns, and sometimes flat sandy turns.
My mileage from a tank of fuel went from around 40 miles to around 65-70 miles. Some came from a more efficient fuel burn, and some of it came from making more power at lower throttle settings, and some from me being more careful with the throttle.
I am happy with the extra mileage, and the extra snap makes me grin.
Good Riding and Wrenching to You!
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 04-17-2018, 08:20 AM
Gibnut Gibnut is offline
2018 EC250 Six Days
NEDW #2, 40p, 172m, a/s 1.5, Motul 710 @ 2% in 98Ron fuel, 0-1000m asl, 5c-35c
The bike was a spooge machine (albeit still making nice fat, slightly doughy power) til I dropped the needle from #3 & the weather started to cool off. 21c today.
I had the bike under heavy load in some steep single this morning & it's lost none of the bottom end with the needle drop as far as I can tell. Pulls pretty much like my Beta RR300 did. No spooge, starting & idling beautifully.
This setting works for me. Hopefully just an a/s tweak &/or clip to #3 in winter is all it'll need.
Loving the bike so far.
Old 04-17-2018, 01:57 PM
Originally Posted by Gibnut View Post
2018 EC250 Six Days
How was the float level from the factory? Are they using the ASII or the AS1 screw top carbs?
Old 04-17-2018, 04:38 PM
The dealer had a look at the float level when pd'ing the bike I believe. The bike does around 10km/L, so economy good.
AS1 with the butter screws - replaced them with a sturdier screw.
Old 04-17-2018, 05:23 PM
That's the AS2, flat cap secured by 2 x m5 bolts.
AS1 is a round internally threaded cap.
Thread Tools
Display Modes
The jetting database needs your help! MattR General Discussions & Announcements 4 10-18-2017 05:34 PM
JD Jetting settings for linear power delivery? SpeedyManiac Enduro Intake/Carburetion - 2 stroke 5 04-06-2010 06:17 PM
Modification/Aftermarket Database SpeedyManiac Enduro Product Reviews 4 02-04-2009 07:09 AM
Jetting Database Announcement MattR General Discussions & Announcements 0 12-18-2008 08:58 PM
Jetting Database Summary MattR Enduro Intake/Carburetion - 2 stroke 0 12-18-2008 08:36 PM
