Old 01-26-2018, 05:48 AM
expirmininkas expirmininkas is offline
Originally Posted by VilluEST View Post
Try and squirt some engine oil in from spark plug hole. If the reading then jumps up to normal or even more, then you have a worn engine. Also, you can test your pressure gauge against some other manometer (tire for ex).
Hi, just "thinking out loud": maybe low compression is due to the influence of decopressor? As its nature is to lower compression for easier starting.
Aslo, is it normal, that exhaust pipe at the cylinder becomes very hot? See picture, taken in the dark garage.
Old 01-29-2018, 12:39 AM
Tafka Tafka is offline
Yes, when there is no air movement the pipe gets nice and red.
Old 01-29-2018, 02:36 AM
Hi,
Thank you!!!! The more I continue to use the bike, the more it is similar to a self-willed person - it is totally unpredictable. On saturday I have heated up the engine, then I've tried to kill the engine and start it again. No problems were found, the engine was starting very smoothly every time. Lateron, when I've got back after some riding, I could not start the engine for the first time after killing - only during the second or the third time, with throttle fully open.
Also, I've bought new compression meter and did the test. The result was similar to this shown in the picture (I am saying similar, as in the picture is the result of testing of perfectly working KTM 560 six days, 2012). So, I presume, everything is ok with the compression?
File Type: jpg IMG-8f471837ca0e468826dec00de8549a77-V.jpg (105.1 KB, 14 views)
Old 02-03-2018, 04:46 AM
I have managed to connect bike to the computer with Guzzidiag. Can somebody tell me are theese readings ok? Se attachment.
Also I've found fault's stored and managed to clear them.
Old 02-05-2018, 12:29 AM
Seems ok
Old 02-05-2018, 01:08 AM
Originally Posted by Tafka View Post
Seems ok
Thank you, and btw, thank you for sharing map file of 2007y. When the weather shall become warm enough, I'll take the bike to the test into forest
Old 02-05-2018, 04:40 AM
No worries, that's why I uploaded those MAP files, so that everyone can access and use them!
Old 05-01-2018, 06:16 AM
portugaldude portugaldude is offline
hi there, how do you upload the files on the bike?
Old 05-02-2018, 12:35 AM
If you don't know how, i wouldn't mess with the ECU....
But this thread should help.... http://www.gasgasrider.org/forum/showthread.php?t=18385
Old 05-07-2018, 07:52 AM
Thumbs down
Hi all,
So, my problems with miss-fire where solved by increasing the number of CO trim up to 45, also, by disconnecting yellow/blue wire (I do not know, which action had impact, but when riding in the forest, I have connected yellow/blue wire back - and I could here some miss-fire occasionally and the sound of exhaust has changed. So, I like it with yellow/blue wire disconnected more ) . However, consumption of gasoline has increased accordingly - now I can ride ~ 70 km with standard gasoline tank (I think the capacity is ~ 6 ltr.).
Starting issues were also solved by doing so: if the bike does not start from the first time, I engage the ignition for the second time, then do WOT, later close throttle and press start button - bike starts perfectly. If not, keeping WOT and pressing starter button helps - starts immediately Ufff, my GG acts like a spoiled person.
p.s. BTW, I have a map from Tafka, 2007y, uploaded to my bike's computer
400 FSE will not idle when hot Gordonian Enduro Engine 4 stroke (including EFI & Exhaust) 5 08-30-2016 09:49 AM
'05 450 FSE Gear Stick/Engine Stall... bhambaker Enduro Engine 4 stroke (including EFI & Exhaust) 9 04-07-2016 10:50 PM
ec 300 2005 won't rev high nor idle... hannesd Enduro Engine - 2 stroke 23 12-17-2012 01:52 AM
300 won't idle. Please help!! stemplin Enduro Intake/Carburetion - 2 stroke 32 04-05-2012 07:28 AM
can,t get idle up geno Enduro Intake/Carburetion - 2 stroke 1 04-18-2010 08:49 PM
