#141
Go for the Ohlins! The ebay one is not a Fox Shock it looks like a stock one.
Claude 2019 XC300 2010 Nambotin 300 sold '07 EC300 sold '06 EC300 sold '78 Suzuki RM250C2 '75 Yamaha YZ250B sold |
#142
Thanks! I am thinking about it.
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
#143
Updates
I found an RM replacement shock and sent it to Drew at Works Enduro Rider. Drew is also going to install a set of Racetech Emulators in the forks. I had a big batch of OEM suzuki parts arrive and started getting them installed.
I pressed new bearings and seals into the upper full floater arm. Everything went together very nice and it was fairly easy to fit to the frame. Just make sure that you don't lose any needle bearings when install the long spacer and long pivot bolt. This is what it looks like installed.That cad plated gold rod in the middle is actually a spacer and the pivot bolt goes through the center. This is a shot from the side which show the pivot bolt and the new linkage arms bolted up with all new Oem Suzuki fasteners including new shock bolts. View from the back, notice the new suzuki chain guard and bolt to the left. New oem engine mount bolts and spacers. New oem rear fender. New oem front plate. New oem fork boots
#144
Updates Continued
I had bought a new Renthal Ultra lite rear sprocket part number 123U. Package showed that it fit all the RM 250s to 2008. Wrong. I spoke to the Renthal rep and he said that the 84,85,86 RM 250 ran a different rear wheel that used Renthal sprocket number 125U. The Sunstar application chart confirms this is correct.After some more research its appears that the 84,85,86 RM 250s used the same rear wheel as the RM 465 and RM 500. After 86, Suzuki went back to the std RM 250 wheel that they used until like 2008.
New oem side panel. These are the big wide 98 RM 250 footpegs. New tank strap. New CDI cushion New CDI strap Tank with new oem fuel valve and cad bolts. New bearing and seal installed on clutch shaft.New main bearings installed into the cases. Clutch cover with the new ceramic coolant seal.
#145
Water Pump
This is the water pump. I ordered new seals and bearings but upon closer inspection I am going to order a new impeller shaft. This shaft is too oxidized to use. This photo includes the new parts oriented on the old shaft that will be replaced.
This is the correct orientation of the ceramic seal for the water pump.
#146
Great pics but I'm on my phone. Might have to view proper on a bigger screen.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
#147
Thanks! Yep, a bigger screen is better.👍
#148
Ok I'm here and it looks fantastic.
#149
Thanks! Its getting there isn"t it?
#150
Engine Build Started
I started on the engine build this past weekend. Here are the cases with the new Suzuki oem bearings installed in each new oem case.
Shift side case. Brake side case. The cases went together without a problem. Everything rotates smooth without any binding, shifts nice.
94 CR 250 Ground Up Restoration IMS Wide Ratio Transmission Issue | Moto7man | All Other Bikes... | 146 | 01-28-2018 05:57 PM |
1994 CR 250 Restoration featured on Dirt Bike Magazine Webpage | Moto7man | Pictures & Videos | 8 | 10-28-2017 09:12 AM |
Gas Gas Contact Jt 25 95 Restoration And Help | Eyetech | General Discussions & Announcements | 1 | 03-18-2016 03:33 PM |
2001 XC200 Restoration Project | Lincolnlock | Enduro Engine - 2 stroke | 19 | 04-22-2014 03:42 PM |
My Stomping ground | swazi_matt | Ride Reports | 10 | 03-02-2011 09:35 AM |
