Old 06-09-2020, 12:00 AM
Cleetis Cleetis is offline
Default Cylinder and Piston Measurements, EC300
I?m freshening up my 2010 EC300 and got the measurements (attached) using a bore gauge on the cylinder and calipers on the piston. What are some of your opinions on plating vs not plating? There is some ovalization in the bore but is it necessary to replate? Either way I?m getting a new top end kit in there. Thanks!
File Type: jpg CF511F44-D616-473C-8415-39DDEDE01B28.jpg (124.6 KB, 20 views)
Old 06-09-2020, 03:39 AM
Find someone who can hone plated cylinders would be surest option. Need fancy honer but that's how they are done original.
Old 06-09-2020, 08:40 AM
The surface itself is pretty clean and smooth. Honing would remove material and I dont think thats what it needs. It doesnt have any damage its just high hour bike and the shape is slightly worn front to back. Based on the dimensions is that wear excessive and worthy of adding material back in? Here is a pic of the bore.
File Type: jpg 00672EC8-C5BA-43B6-B4D7-0F2D92EBC3D8.jpg (114.9 KB, 18 views)
Old 06-09-2020, 09:32 AM
If you can't see the hash marks on the cylinder bore, it's time for a replate.
You will need to send the new piston in with the cylinder when the plating is done.
Old 06-10-2020, 12:41 AM
Found my answer right in the manual, go figure. Limit on the cylinder bore is 72.10mm measured 20mm from upper end.
Old 06-10-2020, 03:44 AM
So a hone should bring it round without breaking through.
Brand new 400 - 450 ??? cylinder and piston Stoby Parts 0 06-18-2015 04:46 PM
Cylinder Plating to Matched Piston ?? GasGasDreamer Enduro Engine - 2 stroke 6 01-13-2014 10:10 PM
EC200 Cylinder Measurements WTEC Enduro Engine - 2 stroke 43 09-11-2013 12:14 AM
