Does your clutch drag?
Just wondering of the GG's out there if most have a dragging clutch?
I.e. with the engine idling engaging gear will make it stall or slow the engine speed noticeably - or in gear with the clutch pulled and pushing the bike there is noticeable drag from the back wheel/chain If you have none of these symptons which gear box oil do you use and are you still on the original clutch?
'05 Gas Gas 300 '97 Aprilia Pegaso 650 '99 KTM 200 '95 ish XR630 (died many times in Oz) |
I dont have a problem,06 ec300 stock clutch,shell rotella 15w40 oil,starts easily in gear as well
I dont have any issues on my 2002 GG EC250 with stock clutch plates and springs. I run Amsoil 0W-40 4 stroke oil. I ride in +30 deg C to +5 deg C.
Mine doesn't drag on either Putoline Light Gear Oil or Halfords Dexron III ATF. I also succesfully used a Motorex light gear oil, can't remember the name though.
First off, bleed your clutch slave cylinder.
If that doesn't fix it, then try AmsOil Formula 4 stroke 0W-40 oil. That cured my '01 XC300 clutch drag. The '06 EC300 clutch seems to be more tolerant of different oils.
mine drags the same way. adjusted the lever all the way. but it still slows in gear with lever in, and moving (off) with level pulled.
how do you bleed it? is it a reverse bleed? ps sorry if some of my posts have misspells, i switched back to dvorak keyboard
Le Crutan 98 ec250 sixdays, doma, eline pipe guard, zokes shivers from a cr250,fredette racing chain slider, protaper withbarkbusters (SOLD) FOR THE SECOND TIME 07 EC300 polisport headlight, acerbis taillight ltr pv cover and case saver,trailtech endurance,120z fww, g2 throttle,xr chain puck: |
Thread Tools | |
Display Modes | |
Yes my Clutch does drag. | (F5) | Enduro Engine - 2 stroke | 42 | 04-09-2019 12:11 AM |
Clutch Drag? | Gas Huffer | Enduro Engine - 2 stroke | 5 | 12-11-2007 05:02 AM |
05' EC300 Clutch Drag | gasIdaho | Enduro Engine - 2 stroke | 18 | 09-09-2006 02:53 PM |
