Old 02-28-2020, 01:55 AM
Anders's Avatar
Anders Anders is offline
After last night's training session, I noticed that the hour counter had passed 250 hours, showing 250.3.
My 2015 EC200 has been with me since October 2015 and has served me well. This means that I have used it for approx 60 hours a year, somewhat less than I had hoped.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 03-01-2020, 12:12 AM
(F5)'s Avatar
(F5) (F5) is online now
Well apart from my new rear bracket for the chain guard posted elsewhere, we did this today
Ahh crap cant seem to load it today. Scenery was stunning. Hot as needed lots of sunscreen.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 03-01-2020, 01:30 AM
Last night's jobs were;
Fit 5.7N/mm rear spring and set sag
Fit new S3 power valve assembly
Fit new FMF gnarly front pipe
2016 RM-Z450
Old 03-07-2020, 08:40 AM
Anders's Avatar
I replaced the left radiator, as it suddenly started leaking. Luckily, I had a pair of secondhand ones laying around.
Tomorrow is race day, the first round of the Norwegian Enduro Cup.
Anders
1986 Duc Mille S2
etc
Old 04-06-2020, 12:48 AM
Anders's Avatar
Put on the summer tires. After a total stop in all types of sports since March 13, we are now allowed to do some riding again. Very limited, though. Maximum 5 persons at the track, and always keeping a distanse of at least 2m between us.
I will be in a group of 5 today, my first ride in a month.
Anders
1986 Duc Mille S2
etc
Old 04-06-2020, 11:26 AM
blitz11's Avatar
blitz11 blitz11 is offline
Not my GasGas, but a GasGas project.
A poster here had problems with the CDI box on his 2000 TXT 280.
Knowing a bit about this stuff, i wasn curious whether another option was available.
I ordered a CDI from a Honda CRF 50. Search AC CDI Box Unit 6-Pin For Honda XR CRF 50 70 80 100 Z 50 CRF50 CRF70 CRF100 Z50 on ebay.
Anyway, i was able to make it work. Checked its advance map, and it seems REALLY close to EC300 timing advance map.
I tested it on my lathe, but i haven't put it in the bike yet. That's for another day. However, it sparks and the timing light shows that it advances like the stock unit (probably within less than one degree), it should work fine.
If you're interested or having CDI issues, let me know, and I can work you though this.
File Type: jpg 1DBC4E06-259D-4D61-A095-764E4770E7D8.jpg (137.0 KB, 21 views)
File Type: jpg 90FBE0CE-4F00-414C-A102-C794640E87F7.jpg (133.6 KB, 14 views)
Old 04-06-2020, 02:45 PM
(F5)'s Avatar
You say advances, but presumably it should them retard significantly back to say 15degrees at peak power as most competition 2 strokes seem to need to survive?
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 04-06-2020, 03:59 PM
blitz11's Avatar
Good point. Thanks for bringing that up. Brain schism. About 10 years ago, i built an ignition using and arduino mini to map ignition timing. That approach could be done here pretty easily with an arduino intercepting and modifying timing, and letting the CDI box provide the spark. (I still have my notes from that exercise). I had forgotten about the timing advance reduction at high speed.D'oh!
I didn't spin it up too fast (maybe 5 k) and the two data points i had (small speed/high speed) were about the same.
OR, instead of the arduino, the easier thing to do would be to buy a PW80 CDI (https://www.ebay.com/itm/IGNITION-CO...oAAOSwAtlcqx4s), figure its wiring, and then run it to check its spark advance curve (all the way to higher speeds). For $16, i could do that experiment, too. Maybe that will be this weekend's project.
Thanks for bringing me back to reality. it might be worth $20 to have a spare/good CDI to check if you have ignition issues.
Old 04-06-2020, 04:38 PM
blitz11's Avatar
Okey Dokey,
Next weekend -here we go.
I found a two-stroke CDI for $13. I am going to give that a run.
Thanks again for pointing that out. You can see the advance curve on the face plate.
Boy, idle hands with the social distancing - gotta' have something to do!
Old 04-07-2020, 12:44 AM
(F5)'s Avatar
Kewl. I've ridden a TZR50, actually both models which were imports, we never got them new. One had an aftermarket cdi. Maybe the same.
Hunt for CR250 ignition curve which is likely a safe reference and likely to be found. Actually I can probably fire up the garage laptop, heck I'd best charge it anyway.
I bought several Ignitech programmable DC CDIs for various mates a a group buy but they came as CR250 kits with a ignition curve and wiring diagram, but of course could be configured to anything with 12v supply and 1 or 2 cylinders.
They went mainly on single roadrace bikes as well as my big block RZ350/500. I did consider whether they could be used on the GG, the question to whether the lighting coils would produce enough power when kickstarting. On the racebikes you (have to) run then with a big capacitor and a Chinese rectifier regulator. 2 steps dump the clutch in 2nd and they fire up.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
DNF today Pepperami Enduro Chassis & Body 6 09-18-2013 11:59 AM
Got my first GG today! RonMexico General Discussions & Announcements 6 02-19-2011 12:39 PM
Went Riding Today and..... coolum74 Enduro Engine 4 stroke (including EFI & Exhaust) 2 11-30-2008 01:12 PM
HELP! I tried to use my gasgas as a jet ski today! sammyj18 General Discussions & Announcements 19 11-21-2008 08:01 PM
SHNF From Today Boomhauer Pictures & Videos 13 10-30-2007 04:18 PM
