Old 07-31-2020, 07:05 PM
Gasser Nate's Avatar
Just go to your local auto store and shop through the heater hose. Found a perfect bend cheap as. I?m replacing the rubber hoses asap though as they tend to be affected by degreasers and swell up.
Old 08-18-2020, 02:36 AM
Anders's Avatar
Anders Anders is offline
I replaced the Rekluse brake tip I installed some months back. It has served me well, but was completely destroyed in the race a week ago.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 09-15-2020, 02:59 AM
Anders's Avatar
I discovered a split in the tank. It was not leaking a lot, but enough to notice.
As my importer didn't have a new tank in stock, I tried to glue it as a temporary fix while I'm waiting for the new tank to arrive from Spain.
Tomorrow I will fill it up and go riding, hoping for the best.
Anders
1986 Duc Mille S2
etc
Old 09-18-2020, 06:55 AM
Anders's Avatar
Rebuilt one fork leg with new innteck bushings and SKF seals. Kyb oil.
Anders
1986 Duc Mille S2
etc
Old 09-18-2020, 11:50 AM
Why only one?
Old 09-18-2020, 02:28 PM
Anders's Avatar
Originally Posted by Doc Brown View Post
Why only one?
The other one will be done in a few days.
Anders
1986 Duc Mille S2
etc
Old 09-21-2020, 08:44 PM
I finally fit up a new battery after the tiny original started to get a little tired on the cold starts. Replaced it with a SSB LH5L-BS. First one I bought was a dud and open circuited under load. 🤬
The second is a ripper and tested out at 290cca. Starts instantly dead cold. Straightened out my bent shift shaft and made a new shift shaft scorpion collar out of alloy rather than plastic which gets dented and causes shifting issues.
Fit up a force accessories rear disc guard. Typical force item didn?t fit and needed modifications to suit the 2018 on swing arms despite being listed for it. Never again will I buy force products.
Old 09-21-2020, 10:45 PM
shawbagga's Avatar
shawbagga shawbagga is offline
Originally Posted by Gasser Nate View Post
I finally fit up a new battery after the tiny original started to get a little tired on the cold starts. Replaced it with a SSB LH5L-BS. First one I bought was a dud and open circuited under load. ��
Force suck. How much was the battery?
'18 Gasgas XC250
Old 09-22-2020, 12:32 AM
Was not cheap, $180 delivered off Fleabay. It is a pity force used to be very good.
Old 09-23-2020, 08:43 AM
TGM_OFFROAD TGM_OFFROAD is offline
Converted my 18 XC300 to a Rieju
DNF today Pepperami Enduro Chassis & Body 6 09-18-2013 11:59 AM
Got my first GG today! RonMexico General Discussions & Announcements 6 02-19-2011 12:39 PM
Went Riding Today and..... coolum74 Enduro Engine 4 stroke (including EFI & Exhaust) 2 11-30-2008 01:12 PM
HELP! I tried to use my gasgas as a jet ski today! sammyj18 General Discussions & Announcements 19 11-21-2008 08:01 PM
SHNF From Today Boomhauer Pictures & Videos 13 10-30-2007 04:18 PM
