Old 06-01-2008, 02:35 PM
KiwiGasHead KiwiGasHead is offline
Cheers fellow gassers - bled clutch line - replaced oil with Bel-Ray 'gear saver' sae80 oil (looks like blood in bottle) clutch is now a smooth operator - can easily start in gear and if have to push bike with clutch engaged & in gear. engine now doesn't 'whirr' when idling in neutral either - highly recommended stuff.
EC125 comin' thru
Old 06-05-2008, 03:14 AM
rupecopp rupecopp is offline
how exactly did you bleed it, not 100% on bleeding the clutch as you can't build preasure like the brakes.
Go the same prob with mine.
where are you in NZ by the way?
Yes my Clutch does drag. (F5) Enduro Engine - 2 stroke 42 04-09-2019 12:11 AM
Clutch Drag? Gas Huffer Enduro Engine - 2 stroke 5 12-11-2007 05:02 AM
05' EC300 Clutch Drag gasIdaho Enduro Engine - 2 stroke 18 09-09-2006 02:53 PM
