Old 02-28-2011, 01:13 PM
GMP's Avatar
GMP GMP is offline
I'd go through the clutch plate by plate and debur everything with a stone or jewler's file. My '03 was a bitch when new and this fixed it. Also, I wonder if the cush drive blocks on the older bikes like Stainless's could be worn, causing unwanted movement in the basket in relation to the center hub/pressure plate, especially when the bike is stalled under load. This would not explain the problem on a new bike though.
A few extra small holes in the pressure plate like shown on the KTM mod can't hurt, but I wouldn't go crazy.
Old 02-28-2011, 03:43 PM
wasp4banger wasp4banger is offline
I have the same probs with my ec300 '06 when i bought it. I pulled the clutch apart, three of the steel plates were warped, new steels and clutch is now good. You need a good flat face plate to check them on. More than 0.05mm of warp and they should be renewed.
Reckon that this is why it gets worse when hot, as the steels expand and increases the warpiness.
Gas Gas EC 300 '06
BMW F650
Old 02-28-2011, 05:06 PM
stainlesscycle's Avatar
when i replaced the steel plates, i checked new ones with feeler gauge/sheet of glass - they were good.. i may try the ktm clutch mod to see if that fixes it.
07 ec300
www.stainlesscycle.com
Old 03-02-2011, 09:42 PM
(F5)'s Avatar
(F5) (F5) is offline
with my 200 I found that the knotches in the inner basket were enough to cause an issue. Once I painstakingly dremeled smooth it would kick in gear again. At least for another year.
Old 03-11-2011, 07:40 AM
whodat's Avatar
whodat whodat is offline
I took a 9.5 magura, hooked it up then took the slave cylinder off the engine, put a spring loaded clamp on it then pulled in the clutch. You get more movement of the piston in the slave cylinder compared to stock however you can just start to see the first o-ring. A clutch failure on a mntn goat trail 90 miles from no where convinced me to not use it.
Old 03-12-2011, 03:36 AM
add add is offline
Try using Castrol MXT oil. I went through all different oils and this seems to be the best when clutch drag is concerned. I've been running this MXT for the last year and when the clutch starts dragging it means its time to change the oil.
Yes my Clutch does drag. (F5) Enduro Engine - 2 stroke 42 04-09-2019 12:11 AM
Clutch Drag Is Not An Issue! Rick Pictures & Videos 7 11-25-2010 07:50 AM
Does your clutch drag? stay_upright Enduro Engine - 2 stroke 11 06-05-2008 03:14 AM
Clutch Drag? Gas Huffer Enduro Engine - 2 stroke 5 12-11-2007 05:02 AM
05' EC300 Clutch Drag gasIdaho Enduro Engine - 2 stroke 18 09-09-2006 02:53 PM
