Old 06-01-2013, 06:35 AM
eviljim eviljim is offline
Default Gearbox oil
What oil should I use in my gear box?
Do I need to buy specialist expensive stuff or can I get away with a a car oil product?
Old 06-01-2013, 06:46 AM
Stoby's Avatar
Stoby Stoby is offline
Bronze Level Site Supporter
Default oil
I've used ATF for the past few years. So far so good .I like the way the clutch feels/works with the ATF
Stoby
Old 06-01-2013, 09:01 AM
'11EC300 '11EC300 is offline
http://www.gasgasrider.org/html/gear...valuation.html
I use Amsoil 0W40 and am happy with it.
2011 EC300
2013 TXT300 Factory Replica
2014 Polaris Assault
2004 Snowhawk 600H.O.
Old 06-01-2013, 05:53 PM
andoman's Avatar
andoman andoman is offline
You'll get almost as many responses as riders.
I use Rotella with 20% ATF. But I have a Rekluse and that combo has given me the best results on 5 bikes.
Newest Spanish Girlfriend: 2011 300 Six Days
My Daughter is a U.S. Marine
Old 06-01-2013, 07:44 PM
M357.5's Avatar
M357.5 M357.5 is offline
I did the same last change, and I'm getting some squak out of the clutch now if I abuse it. Does not drag or chatter, just makes some strange noises. Think I'll switch back and not use the ATF next change. Mine is the stock clutch, no Rekluse though.
2011 EC250 Six Days
Oldest boy = 2012 TTR125
Youngest boy = 2011 TTR50
Nephew = 2002 CR125
Old 06-01-2013, 08:58 PM
Simmo737's Avatar
Simmo737 Simmo737 is offline
I've tried motul transoil, motul transoil expert, gro synth, castrol mtx, motul 7100, castrol ATF, silkolene synth gear oil, delo 400, bp farm oil and belray gear saver in my 2011 and 13 300s.
For me castrol mtx has the least squawk and longest good feel at the lever and easiest to find neutral. It's also well priced in Australia. Mobil took castrol (bp) to court and won over what they were calling synthetic, mtx is now labelled semi synthetic.
All IMHO, and oils are different place to place. Hope tat gives some sort of insight.
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 06-01-2013, 10:50 PM
Front Royalty's Avatar
Front Royalty Front Royalty is offline
Shell Rotella T6 full synth 5w40. $22/gal
'07 GG EC200
'03 CR250
'01 Honda CBR600F4i
'06 YZ250F parting out...
Old 06-02-2013, 12:08 PM
adv rider's Avatar
adv rider adv rider is offline
Default trans oil
I've used Castrol full synth. 5w40, worked good for me. But I only use it because it's what I had available at my shop = free. Otherwise I would try an inexpensive 5w40 motor oil, or in the past I have used the Honda oils 2 stroke gear lube with good results.
You should be changing your gearbox every 2 rides at most- at least that's what I do, so I feel no need to spend a lot on oil, just keep it fresh
2012 xc300 - Great bike! sold looking for 18+
Old 06-03-2013, 06:41 AM
KTMAndy's Avatar
KTMAndy KTMAndy is offline
I have always used put online gp10 gear oil, it works fine when it's warm. Bloody hard work when it's cold. Finding neutrel may as well turn it off and select with your hand.
Tonight I've picked up some ATF, never used it before, but I don't have any gp10 in.
How much does everyone put in? I always put 1ltr in, but I'm been told it should be 800ml?
GasGas Not Ass Gas.... No more KTM EXC'uses...
www.scunnybikers.com
@Ktmandy
Old 06-03-2013, 07:53 AM
eff's Avatar
eff eff is offline
The same here. Works better than the Rotella for me.
2004 GasGas DE250
gearbox question mikevancapel Enduro Engine - 2 stroke 2 01-01-2012 09:57 PM
Wild 300 Gearbox problems case-racing Other GasGas Bikes/Quads 1 09-17-2009 01:51 PM
ec 400 gearbox issue Paul Somerville Enduro Engine 4 stroke (including EFI & Exhaust) 3 09-05-2009 10:17 AM
Milky gearbox oil juzzasmith Enduro Engine - 2 stroke 10 03-12-2007 05:40 PM
EC250 '98 gearbox questions Leon_gasgas Enduro Engine - 2 stroke 16 09-04-2006 04:50 AM
