Old 06-10-2015, 08:03 PM
gg3's Avatar
gg3 gg3 is offline
After I got it back from the shop the rear settings & spring rate felt much better.After following me, a friend suggested opening up the rebound.We eventually went 6 clicks out & it transformed the bike in stability,traction & cornering. Unbelievable difference,I was a friken legend for the rest of the day(in my mind). So there may be more gains to be had with rear adjustment as well.
I was running the same sag figures on my 2010 as well.
Old 06-11-2015, 05:50 AM
webmaster's Avatar
webmaster webmaster is offline
Administrator
I think Mr Jakobi nailed it...
I would add the following to discriminate between sag being off and rebound being off...
If it starts "pushing through the corner right away" then it might be sag. Your steering geometry is off from the get go.
If it won't "hold a line' and tries to push through in the manner described - then it can indicate your rebound dampening is off. I bought WP 4054s upside down fork kit back in the late 1980s to put on an xr250r (it was from white brothers) - it came with a great manual and a description of this symptom and the cure. If you have too little rebound - what is happening is fork comes up as you are in apex of turn (for example) - this rakes bike out loosening the steering geometry as you are mid-turn (or there abouts...)
From my experience, I would add one additional thing to Jakobi's most excellent response. In the past I would find a section of trail or track where there was a section of whoops and a corner(s) that exhibited the issue - I would repeatedly take this same section while adjusting the fork rebound to dial it in. Ensure fork doesn't bottom on whoop section as you are making adjustments - to ensure the fork isn't "packing" as Jakobi described.
Jeff
Old 06-11-2015, 07:10 PM
gg3's Avatar
gg3 gg3 is offline
Brilliant description thanks Jeff.
Entering the corner is fine but from mid corner/apex is steers wide or wants to climb the berm- Rebound! Will start there.
That manual with the symptoms & cures sounds interesting.Any chance of scanning it & posting up?
Old 06-11-2015, 09:42 PM
gasgasman's Avatar
http://www.gasgasrider.org/forum/showthread.php?t=1862
Old 06-11-2015, 11:17 PM
This is probably the most comprehensive well laid out description I have seen. It touches on individual aspects, but also notes how they all need to come together to work as a total system.
http://www.off-road.gr/article11.html
Shimming Brainteaser for the susp-gurus swazi_matt Enduro Suspension 12 09-18-2017 08:15 AM
For all you jetting gurus out there mou636 Enduro Intake/Carburetion - 2 stroke 2 02-20-2015 03:33 AM
Suspension gurus please help stemplin Enduro Suspension 10 12-09-2011 02:33 PM
ECU gurus??? BigChina Enduro Engine 4 stroke (including EFI & Exhaust) 2 05-20-2011 11:40 AM
Need some help from the jetting gurus MattR Enduro Intake/Carburetion - 2 stroke 7 01-29-2008 01:55 PM
