Old 07-15-2019, 02:53 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Default Front wheel spacers question...
Hi all, just looking at the front wheel axle spacers on my 2004 EC300.
Both spacers look identical, 23mm wide with one straight end and one flared end.
1. Is that correct, they're both the same?
2. The flared ends of the spacers must be on the outside and the straight ends slide inside the seals, that's right isn't it?
Thanks, Dave.
Old 07-15-2019, 03:59 PM
OEM part numbers are the same for both right and left. So, should be identical.
Old 07-15-2019, 04:01 PM
Davehuge's Avatar
Thanks, I guess I should have looked at the part numbers myself!
What about the flared ends? Surely they should be on the outside?
All the best, Dave.
Old 07-15-2019, 04:05 PM
All the best, Dave.
Yes, flared ends out. I believe the flared end is to stop the ingress of dirt.
Old 07-15-2019, 04:06 PM
Davehuge's Avatar
Yes, makes sense.
Thanks, Dave.
Old 07-15-2019, 07:51 PM
Actually the flared ends go in to the seal. Their purpose is that they do not fall out when you remove the wheel. They are a good idea but everyone seems to put them in backwards! 😂
Old 07-16-2019, 04:01 AM
Yep, that is the correct way to put them in. My bike came with both installed in wrong direction and it was the same on my mates bike.
That's a pic from the 2018 GasGas "Set Up Manual"
Old 07-16-2019, 04:27 AM
Davehuge's Avatar
Interesting! Thanks for info/photos...
That's the way they were installed when I got my bike (flared end into the seal) but I didn't think it looked right.
It is nice not to have spacers falling out!
Old 07-16-2019, 05:52 AM
You'd think the flare sitting behind the seal lip would also aid with keeping any chunks of debris away from the bearing.. you'd think..
I have always ran both in the same direction.. One in, one out.. Just because.
Old 07-16-2019, 06:59 AM
If you want to have the whole set up manual (as PDF) drop me a line. I was just too dumb to upload it
wtb 2009 front wheel + spacers+ axle jt633 "Wanted to Buy" & "Want To Trade" 5 12-03-2018 03:19 PM
front wheel question jt633 Enduro Chassis & Body 6 12-03-2018 02:50 PM
'06 EC300 ajs front wheel spacers brider Enduro Chassis & Body 10 04-11-2013 08:40 PM
Front wheel spacers. iamyvr Enduro Chassis & Body 4 02-22-2013 10:09 PM
Front wheel question GMP Enduro Chassis & Body 3 12-19-2010 03:46 PM
