Enduro Product Reviews Feedback & Comments on Products Tested |
#11
The big improvement is forward thrust in mud and loose rock.
Braking is a bit better. It doesn't load up with mud as bad. The key too clearing mud out of a trials tire is to run low pressure. This way the tire flexes and opens up after contact with the ground.
Eric K '06 GasGas EC300 '01 GasGas XC300 |
#12
I would think that the remaining knobs may be more prone to shearing off. Stock, the forces on a hard surface like a rock would be limited by adhesion and distributed across several knobs. Modified, you now have more side knob contact, and potentially more force transmitted through the knobs. Being the knobs/compound is very soft and not designed to be loaded in this manner, it could be a weak point. Eric has been doing this so I guess he knows for sure. I will try it with a used tire and see how it holds up in the rocks.
#13
It might be worth trying a Vee Rubber. They are a lot like the michelin in carcuss and knob feel.
Some more cost conscience people use them in trials and flat trackers prefer them over Pirelli. Vee Rubber are also now making a 19" for MX'ers wanting to do flat track.
EC300 2019 (11 Gassers owned, many more to go) |
#15
If you're looking for a cross between a knobby and a trials instead of cutting knobs why not try one of these? http://www.motorcycle-superstore.com...Rear-Tire.aspx
Some are saying that this tire with the Tubliss is a good combo. |
#16
Trials tires are used for the radial design that allows a lot of flex and large contact patch, and the sticky compound. Without this, there is no point in going with a close spaced tire like that shown, at least for technical riding.
#17
I run the Kenda K270 on my TE510. I love that tire! Although it may not flex exactly like a trials tire. I'll tell if you rim locks are snug and you run very low psi (6-8psi). It a great tire and they DO flex quite nicely.
They wear well and are dirt cheap (around $60). But I'm not 100% convinced on running one on my 300 yet. Like stated above I have a Mitas trials I want to try first.
HuskyDude 10 EC300XC 08 TE510 07 TXT 280 77 TY175 |
#20
I'm too happy with my MT43 to switch but I thought the Kenda 270 might work better in the slick mud and brake sliding with Tubliss and about 4psi.
Thread Tools | |
Display Modes | |
Getting trials bike clutch feel on an enduro bike? | SpeedyManiac | Enduro Chassis & Body | 3 | 12-01-2010 02:11 PM |
Tubliss with trials tire | roostafish | Enduro Product Reviews | 34 | 07-22-2010 04:06 PM |
to trials tire or not to trials tire? | boostedte37 | General Discussions & Announcements | 5 | 05-31-2010 11:29 AM |
Trials bike comparison - 99 270 vs 03 280 | SpeedyManiac | Other GasGas Bikes/Quads | 2 | 06-25-2009 11:37 AM |
Trials Tire + Tubliss? | MIKEWA | Enduro Chassis & Body | 7 | 03-18-2008 06:03 AM |
