Old 12-04-2011, 08:43 AM
Eric K Eric K is offline
If you want trials tire like traction with a knobby try the Metzeler Unicross with the Tubliss. The Metz Unicross sidewalls are much softer than most knobby tires giving it a lot more flexibility to adhere to different surfaces. I have run at various pressures.
I have run trials tires for 9 years on my 01 GasGas XC300 and for 3 years on my 06 EC300, including the Michelin, Dunlop, IRC & Mitas radial trials tires. The Mitas was all around the best performer for me.
I have ridden the Metzeler/Tubliss for 1387 miles over 2+ years on my 06 EC300. I ran pressure down as low as 4 psi. I found 6 psi to be the sweet spot for traction and higher speed control. For comparison, I had the Mitas ET-01 trials tire on my 01 XC300 normally at 6.5 psi with a HD tube.
The most difficult conditions where I ride are mostly greasy, wet clay and occasional snow/ice. In same day, same location, back to back comparison riding between my 2 GasGas 300's. One with a Mitas trials tire and one with the Unicross this is what I found: On the greasy clay the Metzeler/Tubliss at 5-6 psi is very comparable to the Mitas at 6.5 psi. On glare ice, they both have difficulty hooking up. In deeper snow, the Metzeler has a clear advantage. In loose rock the Metzeler has a clear advantage. It pulls harder and straighter. On solid, exposed rock the Mitas had a slight advantage. In sand the Mitas has an advantage. Cornering clearly goes to the Metzeler. It is more stable and predictable in hard, leaned over cornering.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 12-04-2011, 11:09 AM
GMP's Avatar
GMP GMP is offline
Tubliss pushes some knobbys close to the trials tire performance for sure. An MT-16 with Tubliss at 6 PSI is excellent as well. In pure rock though the trials rules and saves me a lot of $$ in trashed tires.
Old 12-08-2011, 05:55 PM
trialsridr trialsridr is offline
To offer an opinion on the original question. I agree the dunlop works great for the average competitor on a trials bike for roughly half the money of a Michelin . I could tell little difference between the two if any . I think Jeff Aaron won his last couple national championships with them and I will buy the dunlops again when I need another pair.
Old 12-09-2011, 01:13 AM
I run tubliss here, but find i have to use tires with reinforced sidewall to avoid sidewall cuts, like the mitas c18
2003 txt250 Pro
2013 Ossa 280i
Old 12-09-2011, 08:55 AM
HuskyDude's Avatar
HuskyDude HuskyDude is offline
I've had that problem with the Michelin X11's before. Even punched a small stick right through the side wall.
But in all fairness the tire was a few years old and showed signs of side wall cracking
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 12-09-2011, 09:12 AM
2whlrcr 2whlrcr is offline
Hey Xenia guy, do you know John Manly?
Old 12-10-2011, 12:27 PM
I do not know him
Getting trials bike clutch feel on an enduro bike? SpeedyManiac Enduro Chassis & Body 3 12-01-2010 02:11 PM
Tubliss with trials tire roostafish Enduro Product Reviews 34 07-22-2010 04:06 PM
to trials tire or not to trials tire? boostedte37 General Discussions & Announcements 5 05-31-2010 11:29 AM
Trials bike comparison - 99 270 vs 03 280 SpeedyManiac Other GasGas Bikes/Quads 2 06-25-2009 11:37 AM
Trials Tire + Tubliss? MIKEWA Enduro Chassis & Body 7 03-18-2008 06:03 AM
