Old 09-28-2022, 06:07 AM
brider brider is offline
Default 2002 EC300 swingarm rubbing block replacement options?
Newbie here, bought a 2002 EC300 a while back and haven't done anything but ride it around the yard yet, but yesterday I inventoried all the things I need to do to "dial it in" before the first real ride.
I noticed the chain rubbing block on top of the swingarm at the front (pivot) end was missing, just a broken piece of rubber at the single attach screw on the top side.
I ASSUME this rubbing block wrapped around the front of the swingarm and also attached underneath.
Haven't researched OEM replacement sources yet, is this also available as an aftermarket part? Where?
Old 09-28-2022, 01:16 PM
(F5)'s Avatar
(F5) (F5) is offline
TM designs do one. Just fit one and It's as std
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 09-28-2022, 02:18 PM
Default will '21-'23 fit an '02?
I found this one @ TM Designworks, wondering how far off (if any) this is from fitting my '02?
https://www.tmdesignworks.com/p-2960...n-dcs-kt3.aspx
Old 09-28-2022, 03:51 PM
And do you have to remove the swingarm to install it?
Old 09-28-2022, 05:21 PM
cbutler's Avatar
cbutler cbutler is offline
This is the one you need you must pick Rieju(GasGas)
https://www.tmdesignworks.com/p-145-...n-dcs-ggm.aspx
Yes it can be changed without removing the swingarm just remove chain and sprocket.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Gas Gas light switch block replacement. n_green Enduro Electrical & Wiring 6 01-28-2018 01:59 PM
2012 EC300 swingarm rubbing rear master cyl scorpa1 Enduro Chassis & Body 4 03-24-2014 10:13 PM
rear master cyl rubbing on swingarm? davermb Enduro Chassis & Body 5 07-02-2012 08:16 PM
Master Cylinder rubbing on swingarm Malcolm Enduro Chassis & Body 1 12-13-2009 12:36 PM
Stand Rubbing on Swingarm coolum74 Enduro Chassis & Body 14 06-16-2009 11:31 AM
