2006 EC300 - Removing Wires
Hi, I am looking to get rid of some of the wiring on my bike that I don't need. I don't use any lights, horn, computer is toast, etc. I'm looking to keep just the basics for the CDI and spark. I have 3 wires that go to the coil and voltage regulator and am wondering if I need to keep them all. There is one for the coil, one from the AC that goes into the voltage regulator which I don't think I need, and a ground which I am unsure about. Does anyone know if this is a ground that is needed for the CDI or is it just for the accessories? The coil has a separate ground.
Try not to cut up the main harness if you can avoid it. If your 06 is
like the 02-03 harness I have seen. The CDI circuit is seperate from the lighting one. I would be interested in buying a full EC wiring harness for the lights, brakes, horn, turn signals etc...etc... I have bought two from other forum members in the past. One for my XC300 to convert it to an EC. And one is now on my KDX240. (Going for a full street legal KDX) Sorry I did not answer your question exactly..... |
You're right, the lighting harness is separate and can be unplugged from the rest. I plan to leave that intact and wire the 1, 2 or 3 wires I need for the coil separately with new wire. Just need to figure out which ones I need.
Thread Tools | |
Display Modes | |
2006 EC300 problem | fury1 | Enduro Engine - 2 stroke | 29 | 06-09-2009 05:40 PM |
2006 EC300 bars | colinmc400 | General Discussions & Announcements | 3 | 04-25-2007 08:23 PM |
