Old 05-06-2018, 03:52 PM
sheepy sheepy is offline
Default ec 300 2012 jetting (needles)
ive just done a full engine rebuild and after a few rides thought it was running a bit lean it was overheating blowing out coolant and pinking. so i pulled out the carb as1 and found a 170 main jet, 40 pilot, n1ef needle on top clip, air screw 3 turns. so ive put it back to the standard 42 pilot, 175 main, n1ef #2 and air screw 2 3/4 turns. and i find that it is to rich from around 1/8 throttle all the way to wot. i understand 2 3/4 turns is to far out should be between 1 and 2 for best results so going to drop back down to 40 pilot. but for the top end was thinking of running a different needle either a n3ch or nedj do you think they will be suitable with the current jets? will be used in-between 50-2000ft
Old 05-06-2018, 03:57 PM
float height has been set to 10mm couldn't bring myself to go to 16mm can see how any fuel would get in if set that low. the float is about 10 degrees from parallel with the carb body. am i right in thinking that the NEDJ will give a more smoother power delivery as the N3CH will give you more off a kick in the mid range. how do these needles respond to the mapping switch?
Old 05-06-2018, 08:14 PM
Surely you have an AS2 carb with screws holding the cap on? Think they came in from 10 on or there about. 3 mates 2010, 13, 15 all changed to the RM needle suggested and transformed their bikes. I've ridden 2 of them and they are as close as I'd ever bother trying for. And give good mileage as a side benefit.
Old 05-07-2018, 03:26 AM
Definitely an as1 carb it?s printed on the right had side above the float bowl pwk as1 0 bf9 but the screws hold the top down meaning there is no threads in the cap on top
Old 05-07-2018, 03:45 AM
Well I don't know what to say.
I've been calling my round cap one an AS1 and the later 2 screw flat tops AS2.
Either way the flat ones are later.
Old 05-07-2018, 09:41 AM
Sorry my mistake it is a as2 it?s stamped al1 not as my mestake. So what jets do people run with the Suzuki needles neXX and n3xx needles ?
Jetting (needles) 2013 gasgas ec 250 nickp Enduro Intake/Carburetion - 2 stroke 7 11-03-2013 02:25 PM
2012 300 jetting bones150 Enduro Intake/Carburetion - 2 stroke 3 05-10-2012 05:56 AM
2012 300 JD jetting kit mblazer11 Enduro Intake/Carburetion - 2 stroke 11 04-17-2012 10:12 PM
Where to buy needles. Other jetting questions. IDAHOSPUD Enduro Intake/Carburetion - 2 stroke 1 11-07-2011 02:08 PM
JD Jetting Spreadsheet - anyone know codes for JD needles ?? DaveH Enduro Intake/Carburetion - 2 stroke 1 02-13-2011 09:40 AM
